Old 11-18-2016, 06:46 AM   #1
36 CS
Default 36 stainless welting
I am having problems installing stainless
welting between the fender and the horn grill Pc. of sheet metal on my 36.
Any pointers to make easier?
Best vendor to buy from.
Do I have to completely remove fender?
Thanks guys for all your help.
36 CS is offline   Reply With Quote
Old 11-18-2016, 11:07 AM   #2
J Witt
J Witt's Avatar
Default Re: 36 stainless welting
I bought my welting from Joe's Antique Auto. The individual pieces took a moderate amount of rebending to fit correctly, but I've not been able to get them fitted as well as the original ones. Probably just me being impatient.
I had the side panels removed, but you shouldn't have to do so and the fenders stayed in place. I put the horn side panels in place with all the bolts in, but left loose. Mine were off the car for engine removal.
You can then carefully pry a gap between the fender and the side panel using a thin flat blade screwdriver to give enough room to slip the flap in place. I had a helper hold the welt down flush with the fender while I tightened the bolts. The headlight then went on last. If you haven't unbolted those side panels, there are 6 bolts on each side to loosen, they all have blind nuts. Here's a picture of the joint without the side panel.
John
Houston, Tranquility base here. The Eagle has landed.
J Witt is offline   Reply With Quote
Old 11-18-2016, 04:17 PM   #3
slowforty
slowforty's Avatar
I had the same problem with my 40. I cheated an stapled the welt in place. I think it would be possible to glue the welt in place,with some of the new type glues.
slowforty is offline   Reply With Quote
Old 11-18-2016, 11:00 PM   #4
gnolnor
gnolnor's Avatar
I had a Drake repro SS welting. They did not fit and had a weird bend in them that did not conform to the fender. I ended up searching and buying original welting pieces for both fenders, They fit fine and were fairly easy
to install.
gnolnor
gnolnor is offline   Reply With Quote
Old 11-19-2016, 11:13 AM   #5
36 CS
I have a Drake set and they do not fit well. Steele has chrome welting. They were going to try and send me a sample . They may look good , I may buy enough to make a set. Thanks a lot for the info.
Old 11-19-2016, 01:54 PM   #6
blucar
blucar's Avatar
Stainless Steel fender welting is quite easy to install if the fenders are loosely attached to the body.
Carefully form the welting to fit the shape of the fender, then mark the bolt holes and cut a U shape into the welting fiber strip at each bolt. Carefully slide the welting into place, reshaping it as you go, as needed. Once the welting is in place go around the fender tightening the bolts. Don't snug the bolts up, work you way around the fender.
Take tour time, HAST MAKES WASTE. Actually the stainless welt is installed just like fabric welt, just a little more time consuming.
Bill.... 36 5 win cpe
Thread Tools
Display Modes
