Old 04-11-2016, 10:05 AM   #1
CT Jack
CT Jack's Avatar
Default U Joint Installation
I will be reinstalling U joint and would like to know how much grease to repack assembly with. I plan on using JD Corn Head Grease. It is a polyurea base grease that is thixsotopic which allows the grease to flow and recirculate within the U joint cavity. Searching other threads most say pump grease through zerk until it starts to exit speedo connector. I have seen photos of an assembly without the covers where the U joint is completely packed in grease before installation. What is the best way?
CT Jack is offline   Reply With Quote
Old 04-11-2016, 10:49 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: U Joint Installation
Pack joint with grease and then pump into cavity as explained, about a tube in total. If you pump in too much it'll go into the transmitter.
Old 04-11-2016, 11:11 AM   #3
pgerhardt
pgerhardt's Avatar
Auto correct again!
If on a Mac here is how you can turn it off:
Open System Preferences (choose Apple > System Preferences).
Choose Keyboards.
Click the Text tab.
Deselect the tick in Correct Spelling Automatically.
pgerhardt is offline   Reply With Quote
Old 04-11-2016, 08:30 PM   #4
Patrick L.
Patrick L.'s Avatar
Originally Posted by pgerhardt View Post
Auto correct again!
Choose Keyboards.
Click the Text tab.
Typed as I spelled it. If the rear bearing is an original style, u-joint grease can slip past into the transmitter. The transmitter is that little gizmo between the flywheel housing and the clamshell that some folks refer to as a transmission.
Old 04-11-2016, 09:02 PM   #5
SeaSlugs
SeaSlugs's Avatar
well TECHNICALLY its a transmitter of power where you get to select the ammount that is transmitted and what direction haha
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
