Old 04-23-2015, 04:57 PM   #1
Redbird
Redbird's Avatar
Default Lug nut torque
What should lug nuts be torqued to?
Redbird is offline   Reply With Quote
Old 04-23-2015, 05:01 PM   #2
19tudor29
Default Re: Lug nut torque
Tighten with your crank lug wrench so you can get them off on the side of the road. Don't ask me how I know!
19tudor29 is offline   Reply With Quote
Old 04-23-2015, 05:09 PM   #3
Patrick L.
Patrick L.'s Avatar
50 lb/ft
Old 04-23-2015, 05:11 PM   #4
Mitch//pa
common sense and recheck them after some use
Old 04-23-2015, 05:39 PM   #5
V4F
V4F's Avatar
as said , use your lug wrench so you can get them off ....
V4f
V4F is offline   Reply With Quote
Old 04-23-2015, 07:16 PM   #6
Redbird
Redbird's Avatar
Thank you guys!
Old 04-23-2015, 10:46 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
Lubed of not?
Old 04-24-2015, 06:35 AM   #8
Redbird
Redbird's Avatar
Never lube lug nuts. Just clean off with a wire brush.
Old 04-24-2015, 07:07 AM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
I always put grease on the threads and bevel. That way they don't rust tight and will come off when I need to remove them. Lately I've had to change a lot of flats on my trailers. These newer tires sure dry rot quickly.
Old 04-24-2015, 08:15 AM   #10
Mitch//pa
i use a tad of never-seize
Old 04-24-2015, 10:00 AM   #11
jax55
jax55's Avatar
Never seize has worked well for me too. Friend had a flat on his car trailer, he tore up the threads and had to replace the hub (no lube on threads). I have had a flat on cars and trailers, never had a problem hot or cold.
jax55 is offline   Reply With Quote
Old 04-24-2015, 10:47 AM   #12
rocket1
always check that the lug nuts don't protrude through the back of the wheel mounting holes,some lug nut holes are badly worn oversize.
rocket1 is offline   Reply With Quote
Old 04-24-2015, 11:42 AM   #13
Patrick L.
Patrick L.'s Avatar
I too use never-seize. If I don't have access to it then they get oil or grease.
Old 04-24-2015, 03:19 PM   #14
40 Deluxe
Standard torque nowadays for a 1/2" fine thread lug nut is 100 ft. lb. I think Ford's steel alloy back then was as good as today's, and 50 ft. lb., to me, may let the wheel 'fret' a little and work its way loose. Borrow a torque wrench if you don't have one and torque a few lug nuts to 100 ft. lb., then loosen with the crank handle or whatever you normally use. See how it goes.
P.S. Harbor Freight has torque wrenches for $9.99 with a coupon from a magazine ad. I've tested them with an electronic torque gauge and they are within a pound or so at 100 ft. lb.
Old 04-24-2015, 04:21 PM   #15
J Franklin
J Franklin's Avatar
Do NOT Torque to 100# But then it is your car/hubs.
Old 04-24-2015, 04:26 PM   #16
stouchton
stouchton's Avatar
DANGER - INCOMING GEEK ALERT!!!
Just for fun, I chucked my lug wrench (normal Model A size) onto the digital torque meter here at work. Leaned on her like I was loosening a lug nut and measured darn close to 50ft-lbs. I could have pulled harder, but never remember doing so to loosen a wheel.
So for me, 50ft-lbs sounds good.
Always good advice to check prior to a drive.
stouchton is offline   Reply With Quote
Old 04-24-2015, 04:44 PM   #17
Patrick L.
Patrick L.'s Avatar
That can't be stressed enough ! These wheels have staying put/on for over 80 years at 50#.
Old 04-24-2015, 05:47 PM   #18
stouchton
stouchton's Avatar
I would imagine 100ft-lbs would just wallow thru the wheel....
Here we come a wallowing thru the wheel so tacoma cream,
(somebody fill in next line... and no alcohol was not involved!)
Old 04-24-2015, 06:18 PM   #19
bambooboy
bambooboy's Avatar
do,da do,da
bambooboy is offline   Reply With Quote
Old 04-24-2015, 06:33 PM   #20
stouchton
stouchton's Avatar
now I think alcohol WAS involved
