Old 09-27-2010, 03:32 PM   #1
Joop
Joop's Avatar
Default Mitchell overdrive with cable shifter for Model A Picture wanted
I like to install my Mitchell overdrive in the Model A using the cable shifter as in the later Fords
Could someone please post or send me some picture how they installed the push pull lever in there car.
I asked this question before on the Old Board but that is not accessible any more??
Thanks.
[email protected]
Joop is offline   Reply With Quote
Old 09-27-2010, 03:46 PM   #2
BruceKC
BruceKC's Avatar
Default Re: Mitchell overdrive with cable shifter for Model A
Mitchell now has a cable shifter for there overdrive. Bruce
BruceKC is offline   Reply With Quote
Old 09-27-2010, 04:22 PM   #3
Joop
Joop's Avatar
I bought one but like to know how it looks installed inside the car
Old 09-28-2010, 05:20 AM   #4
flatmotor40
flatmotor40's Avatar
I put one in my 40 conv run the cable down the drivers side of frame up teh firewall and put it by the left of the steering column.This works great.If any trouble call Sue at Mitchell she knows everything
flatmotor40 is offline   Reply With Quote
Old 09-28-2010, 05:16 PM   #5
oldredford
Do not install/use the cable shifter in your Ford period. I did and it is crap...Use the Floor shift with linkage to the Mitchell. You will be glad you did. This comes from experience. Mitchell will supply either the cable or shifter with linkage. Same price but the shifter/linkage is better awhole lot better.
oldredford is offline   Reply With Quote
Old 09-28-2010, 08:38 PM   #6
38 coupe
38 coupe's Avatar
I have been thinking of getting a reproduction Columbia control cable and rigging it up to shift a Mitchell. Has anyone done this?
Old 09-29-2010, 04:30 AM   #7
Joop
Joop's Avatar
[QUOTE=flatmotor40;88931]I put one in my 40 conv run the cable down the drivers side of frame up teh firewall and put it by the left of the steering column.This works great.
Can you post some pictures.
Old 09-29-2010, 05:46 AM   #8
flatmotor40
I've had no trouble with the cable did not want a hole in the floor and a shifter in the way
Old 09-29-2010, 07:21 PM   #9
Joop
Joop's Avatar
Would love to get some pictures
Old 09-29-2010, 07:55 PM   #10
sturgis 39
I have a Columbian rearend. I would like to know more about the after market mechanical shifter. Pictures, names and addresses would be nice.
thanks
sturgis 39 is offline   Reply With Quote
Old 09-30-2010, 05:17 AM   #11
Joop
Joop's Avatar
Btt
Old 09-30-2010, 08:49 PM   #12
sturgis 39
Default Re: Mitchell overdrive with cable shifter btt
What does btt stand for?
Old 09-30-2010, 09:26 PM   #13
Henryat1140
Henryat1140's Avatar
Sturgis39
The Mitchell Overdrive info # would be 800-859-2088
Henryat1140 is offline   Reply With Quote
Old 10-01-2010, 09:09 AM   #14
1931 flamingo
1931 flamingo's Avatar
Joop: my Dad's 50 ford V8 w/overdrive had it cable actuated, You might be able to adapt something like that. I would think for or merc, probably 49-54 or so might work. Hope this helps.
Paul in CT
Old 10-01-2010, 10:21 AM   #15
Joop
Joop's Avatar
Paul.
Thinks for the info
I did get the cable at Mitchell but like to get some info/pictures how it is/was installed in a Model A or later V8
Old 10-01-2010, 11:05 AM   #16
1931 flamingo
Joop: Cable on 50 fordd was mounted under dash to left of steering column aabove emerg brake handle, I think. Long time ago, maybe somebody has a picture they could post? By the way, love your coupe.
Paul in CT
Old 10-02-2010, 06:58 AM   #17
Joop
Joop's Avatar
Default Re: Mitchell overdrive with cable shifter for Model A Picture wanted
The Coupe is nice we love it.
But still looking for pictures for the cable installation
Old 10-02-2010, 05:13 PM   #18
oldredford
I would say 99% of the Model A Fords use the floorshift unit with linkrods to the Mitchell unit. The cable is no good just my 2 cents...
Old 10-03-2010, 07:13 AM   #19
Joop
Joop's Avatar
oldredford I value your opinion but still looking for pictures of cable installation
Old 10-09-2010, 12:20 AM   #20
sturgis 39
Are we going to get some pictures?
