02-08-2015, 09:49 PM | #1 |
46 ford speedometer to C4 tranny? How?
I'm putting a 351W with a C4 transmission in my '46 Ford. I want to use the original speedometer. What cable should I use, and does anyone make an adapter. I can't seem to find anyone that knows.
02-08-2015, 10:11 PM | #2 |
Re: 46 ford speedometer to C4 tranny? How?
Here is a link to some adapters from SUMMIT, give them a call, maybe the'll have what you need.
http://www.summitracing.com/search/p...cable-adapters .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
02-08-2015, 10:38 PM | #3 |
read the earlier post about the 64 fairlane and the 3 sp. trans. the reply about Bob's speedometer may be your answer. one post by "lowrider" has a phone #
02-08-2015, 10:48 PM | #4 |
I think if you use the cable assembly from any older Ford with a C-4 it will hook up.
02-08-2015, 11:04 PM | #5 |
C-4's were first used in 1964 and were used into the early 80's
I think many auto parts stores may have those cables available yet. .
02-09-2015, 10:32 AM | #6 |
02-09-2015, 08:55 PM | #7 |
Mustangs too should work. They come in various lengths. Just make sure the ends are compatible with your speedo as there were different ends over the years.
02-10-2015, 09:15 AM | #8 |
I took the speed-o-meter end off the stock 36 Chevy cable and installed it on the Ford cable to make the 351C/FMX work. The ends of the drive cable turned out to be the same "squished square", just measured the distance the end needed to stick out from the seat on the 36 cable, pulled the drive cable out, cut off the plastic fitting on the Ford cable, pulled the housing out of the 36 head, used a drift punch to "un-crimp" the 36 head, slid it on the Ford cable, trimmed as required, a couple of drops of epoxy, slid the head back on the cable and used wire crimpers to pinch it. Did that in 1979 and it was working last weekend when it went out for it's weekly drive.
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
02-11-2015, 04:52 PM | #9 |
Gotta watch out with some of these tranny swaps.
If you put a 1957 or Later Fordomatic in a '54, 55 or 56 Ford the speedo will never work. The '57 and later Fordomatics had aluminum rear extension housing with the cable hole aiming the speedo drive gear on the opposite side of the drive gear which ends up turning the speedometer cable backwards. Thus the speedo will never register mileage. The only way to fix that is to swap the '57 rear extension housing with a '56 or earlier. I have one out of a '1953 Fordomatic that does fit, but it is made of heavy cast iron. You also need to use the old '54/55/56 speedo cable and driven gear, but you must swap out the later transmission drive gear with the older '54/55/56 drive gear. It is very difficult to remove the C-ring that holds the drive gear on the output shaft and almost as difficult to get it back on again, even with the proper tool. |
02-12-2015, 03:35 PM | #10 |
I don't think you read my question. The solution? you gave had nothing to do with my problem. Anyway thanks for trying to help.
02-12-2015, 03:56 PM | #11 |
Check with gene at Flat-o http://flat-o.com/accessories/speedcable.htm. He makes adapter to mate the C-4 to Flatties and also makes custom speedo cables to work with the stock speedos/C-4. Also has Ratio adapters so the speedo read correctly.
I'm sure he can help you. |
02-12-2015, 06:12 PM | #12 | |
I understand your question and offered a fix, others had viable solutions as well. Granted mine is not off the shelf but the fix can be accomplished with basic hand tools.
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II Last edited by Ford blue blood; 02-12-2015 at 06:14 PM. Reason: spelling |
02-12-2015, 07:53 PM | #13 | |
Bill, I did similar to what you did years ago when I fitted a top loader to my Oz 58 Mainline and Oz 58 Customline. I used the original cable, ground the gearbox end off and did the same with the cable that came with the gearboxes. Pushed the later end on the cable crimped it up and they are both still going nearly 22 years later.
For my recent resto on my 55 Tudor with an FMX fitted I am using a 68 Mustang cable, came with all the right ends but uses a different speedo gear which rotates in reverse as the cable is mounted on the top of the extension housing not the bottom.
Rick West Australia 1958 Ford Mainline Utility, 1955 Ford Tudor Sedan Quote:
02-17-2015, 11:59 AM | #14 |
lokar performance parts makes a cable for 46 speedo to c4. Used one before works great not expensive. They are online
