Old 02-24-2021, 04:48 PM   #1
Bob Johnson
Bob Johnson's Avatar
Default Removing engine/transmission
Where is the center of gravity with respect to the spark plug holes for a Model A engine with the transmission attached?
Bob
Bob Johnson is offline   Reply With Quote
Old 02-24-2021, 05:40 PM   #2
Harpkatt
Harpkatt's Avatar
Default Re: Removing engine/transmission
Can you clarify what your asking for?
Harpkatt is offline   Reply With Quote
Old 02-24-2021, 05:58 PM   #3
Gene F
Gene F's Avatar
Depends on if you are taking them out engine and full trans, or engine and bellhousing area, or just the engine.
Old 02-24-2021, 06:25 PM   #4
Bob Johnson
It is removal of the engine with the bell housing and transmission attached.
Old 02-24-2021, 06:56 PM   #5
nkaminar
nkaminar's Avatar
Start with your lifting ring screwed into the third spark plug hole. You will need to tilt the engine with the aft part lower to get it out. Remove the shift tower and cover the transmission to keep stuff from falling into it.
Old 03-01-2021, 05:55 PM   #6
Gene F
Gene F's Avatar
He is right. holes 1, and 3. A good helper is handy too.
Old 03-01-2021, 07:28 PM   #7
JayJay
A real helper to shift the angle of dangle of the engine/tranny as you remove it is a load leveler like this.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 03-01-2021, 07:43 PM   #8
kawagumby
kawagumby's Avatar
JayJay
Without a load leveler, my engine pulling experience would have been tragic. It almost was anyway. There's just not a lot of room to work with.
kawagumby is offline   Reply With Quote
