Old 11-06-2019, 02:05 PM   #1
M2M
M2M's Avatar
Cool Do I need this?
M2M is offline   Reply With Quote
Old 11-06-2019, 02:14 PM   #2
M2M
M2M's Avatar
Default Re: Do I need this?
And speaking of Optima, in Europe they also get 6v yellow tops.
Old 11-06-2019, 02:26 PM   #3
Jacksonlll
Jacksonlll's Avatar
That is a huge waste of money. Just my opinion.
Old 11-06-2019, 02:41 PM   #4
J Franklin
J Franklin's Avatar
Originally Posted by M2M View Post
Why are your posts so GIGANTIC?
Old 11-06-2019, 02:49 PM   #5
alexiskai
alexiskai's Avatar
I did connect batteries in parallel like that one time, and they were Optimas, but the only reason I did it is because I had accidentally deep-discharged one of them – to the point where my trickle charger wouldn't start the flow of power when I connected it.
Someone then informed me that you could connect another battery in parallel between the dead battery and the charger, get the charger to start sending power to that battery, and the power would "overflow" to the dead battery. And then after doing that for a while you take the second battery out and recharge the first one like normal.
And it totally worked. Brought that Optima back from zero.
I dunno why you would do this in a car, though. Like if you cannot run your Model A off an Optima red-top, you have other problems.
Old 11-06-2019, 02:52 PM   #6
M2M
M2M's Avatar
I'm trying to help out the vision impaired community.
Old 11-06-2019, 02:58 PM   #7
woofa.express
woofa.express's Avatar
M2M, You're doing okay.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 11-06-2019, 03:05 PM   #8
M2M
M2M's Avatar
I can think of one reason. Although this setup still gives you 6v I think it boosts the cold cranking amps tremendously which would be good to have in Arctic winter temperatures of below -40. Your vehicle’s battery loses 50% of its power when the temperature falls below 0 degrees F (-18 degrees C).
Old 11-06-2019, 03:25 PM   #9
Ford-A-baquet
Ford-A-baquet's Avatar
50% of battery power is sufficient to fire the sparks. You stay in front with the crank, that helps to withstand the arctic winter.
Sorry, here the link :https://www.batterystuff.com/kb/arti...-tutorial.html
Ford-A-baquet is offline   Reply With Quote
Old 11-06-2019, 03:44 PM   #10
M2M
M2M's Avatar
Stay in front with the crank you say...
Old 11-06-2019, 04:17 PM   #11
alexiskai
alexiskai's Avatar
Try this:
https://www.amazon.com/gp/product/B000I8XD9E/
80 Watt 36" Battery Thermal Wrap. Keeps the battery warm. Much cheaper than buying a second Optima red-top.
Old 11-06-2019, 04:49 PM   #12
Kurt in NJ
Kurt in NJ's Avatar
A few years ago we had a several day real cold spell, the A had been sitting for 4 months, no charger, the 10 year old optima, a single one was enough at -10 to start it
Old 11-06-2019, 04:52 PM   #13
Ford-A-baquet
I do not think you will reach the zone of the polar bears with your ford a
Old 11-06-2019, 04:53 PM   #14
Ranchero50
I keep a trickle solar charger on my truck to help keep the Optima topped off during the winter. Makes a difference.
Building a '29 Speedster, the hard way...
Ranchero50 is offline   Reply With Quote
