08-12-2019, 08:25 PM | #1 |
rebuilding shifter forks
Got my dad's transmission apart and one of the shifter forks is worn where the shift lever ball slides into it. Does anyone have any experience fixing these. They do not seem like they are being reproduced, surprising as everything else is.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
08-12-2019, 08:32 PM | #2 |
Re: rebuilding shifter forks
Check your Local Model A club,I'm sure someone has a few sets lying around they would be glad to donate.!
www.whidbeymodelaclub.com |
08-12-2019, 08:33 PM | #3 |
Usually 2nd & 3rd fork is worn. Switch the forks & use the worn one for 1st & rev the good one for 2 nd & 3rd.
08-12-2019, 08:37 PM | #4 |
The slots can be welded up and milled. Beware of the repos they are terrible.
Tom Endy |
08-12-2019, 10:46 PM | #5 |
I had this problem and was lucky enough to find an old-fashioned welding and tool repair shop in a nearby town. Just one guy in the workshop behind his house. He welded up the ball and the forks and they work great. Also worked on my steering arms. Maybe someone in your area is still doing this work. It doesn't take special Model A expertise, they just need to restore the slot to square and make it the proper width for the ball.
08-13-2019, 02:27 AM | #6 |
08-13-2019, 06:07 AM | #7 |
Thanks for advice. Will consider options.
08-13-2019, 09:35 PM | #8 |
frank I can restore your forks and have some all done
08-15-2019, 04:50 PM | #9 |
Bert,s Model A could provide a good original one.
John
Welcome each day |
08-16-2019, 10:08 AM | #10 |
If the notches on the forks are worn, good chance the ball on the lever is too.
08-16-2019, 12:12 PM | #11 |
A tower overhaul seminar is a good project for a club seminar. The attached article is about one that was conducted for my local club.
Tom Endy |
