03-28-2018, 05:24 PM | #1 |
Vaccuum wipers
What lubricant should I use on the paddle. I do not have a kit I just want to clean up this thing.
03-28-2018, 05:40 PM | #2 |
Re: Vaccuum wipers
Bad spelling day. Vacuum. After cleaning the original lube/grease what should I use.
03-28-2018, 06:45 PM | #3 |
Re: Vaccuum wipers
I use 3 in 1, or sewing machine oil.
Let's let pylons, be pylons! |
03-28-2018, 08:45 PM | #4 |
Re: Vaccuum wipers
Thanks.
03-28-2018, 08:53 PM | #5 |
Re: Vaccuum wipers
Vaseline
03-28-2018, 09:12 PM | #6 |
Re: Vaccuum wipers
03-28-2018, 09:50 PM | #7 |
Re: Vaccuum wipers
Vaseline also.
03-29-2018, 06:21 AM | #8 |
Re: Vaccuum wipers
I’ve been told 3 in 1 oil will gum up a sewing machine, sewing machine oil only!
03-29-2018, 07:01 AM | #9 |
Re: Vaccuum wipers
How do you use vaseline inside the wiper?
03-29-2018, 07:43 AM | #10 |
Re: Vaccuum wipers
Curtis, you need to take the motor body apart, clean all the old grease and gunk out and off of everything, then wipe a good film of vaseline on the paddles as well as both sides of the lower half where the paddles contact the body as they rotate back and forth.
03-29-2018, 10:15 AM | #11 |
Re: Vaccuum wipers
I use ATF for my sewing machines, and I'd use the same for my wiper motors.
03-29-2018, 12:29 PM | #12 |
Re: Vaccuum wipers
Cleaned everything. I did not replace the paddle seal as it is still in good condition. I thought about ATF, Brake fluid etc. but decided not to go with those because of settling. I used white lithium sparingly and the motor works great. I have to keep in mind what certain lubricants will do in cold weather.
03-29-2018, 01:44 PM | #13 |
Re: Vaccuum wipers
Couldn't find the Vaseline? I guess the stuff you used will be ok.
03-29-2018, 04:52 PM | #14 |
Re: Vaccuum wipers
I don't think Vaseline would work well in cold weather.
03-29-2018, 05:52 PM | #15 |
Re: Vaccuum wipers
White lithium will separate and dry out. I quit using it 20 years ago when I discovered this, and have used Mystik JT-6 High Temp red grease since that time. ATF will still be my lube for all my Studebaker vacuum wipers, as it will stay thin in cold weather.
Cold weather is never a problem though, because then road salt keeps all my good cars put away for 6 months. |
03-29-2018, 06:55 PM | #16 |
Re: Vaccuum wipers
sheesh... now you tell me.
03-29-2018, 11:14 PM | #17 |
Re: Vaccuum wipers
Don't worry, your fix may outlive you!
03-30-2018, 09:21 AM | #18 |
Re: Vaccuum wipers
J Franklin......That's funny, Wait that's not funny.
03-30-2018, 12:21 PM | #19 |
Re: Vaccuum wipers
