Old 01-02-2016, 03:04 PM   #1
pgerhardt
pgerhardt's Avatar
Default need Hood shelve replacement
I started preparing the hood shelves from my 29 tudor for repainting. Much like the rest of the car once I started sanding I found evidence of a fast cheap repair, (picture) plus the screw holes are awfully ragged. I know finding original ones would be best, but in case I can't find any, has anyone had any experience with the repop ones. How good/bad are they?
Thanks in advance for your help!
File Type: jpg Screen Shot 2016-01-02 at 3.03.18 PM.jpg (57.9 KB, 107 views)
pgerhardt is offline   Reply With Quote
Old 01-02-2016, 04:38 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: need Hood shelve replacement
The only time I dealt with a repro was on a 1929 Special Coupe the body shop painted for a customer. I don't recall them having any issues, but I was mainly there to install the engine and get it running.
Am I seeing a cloth and fiberglass repair on the underside of your hood shelf?
Old 01-02-2016, 05:07 PM   #3
2manycars
2manycars's Avatar
the reproductions are not as nice as the originals, and the curves are not exact, and the metal seems thinner. Once installed, most people would not know the difference. Have you called Bert's to see if they have any good originals?
2manycars is offline   Reply With Quote
Old 01-02-2016, 06:13 PM   #4
billy myers
I am in east granby ct I have some originals that could be used or I can repeir what u have
billy myers is offline   Reply With Quote
Old 01-02-2016, 06:40 PM   #5
ericr
ericr's Avatar
I found that the repros needed quit a bit of trimming, the edge that faces the fender was too high and I cut it down till the wood blocks were slightly visible. I also had to cut some metal off of the front of it where it covers the frame horn. I used a beat-up original as a model to know where to trim.
ericr is offline   Reply With Quote
Old 01-02-2016, 07:05 PM   #6
fiftyv8
Repo's will always be 2nd to originals in this case.
My buddy got a real nice pair from Speedway Motors of all places, but I would ring Steve at Bert's first up and see what he has in his used department.
Otherwise, maybe best considering a repair job.
Surely, it can't be that hard to fix...
fiftyv8 is offline   Reply With Quote
Old 01-02-2016, 07:50 PM   #7
pgerhardt
pgerhardt's Avatar
I don't think it is even that good. It looks like that mesh you can stick down to fill a hole with Bondo! That is why I need to replace them!
Old 01-02-2016, 07:54 PM   #8
pgerhardt
pgerhardt's Avatar
I think I would rather tweak real steel to fit rather than have plastic repairs.
Same as above, but I'll give Bert's a call on Monday.
Old 01-02-2016, 07:57 PM   #9
Mitch//pa
Yep it's been molested
