11-05-2020, 08:08 PM | #41 | |
Re: Overdrive Transmission in a 1952 F1
11-05-2020, 08:27 PM | #42 | |
11-06-2020, 11:33 PM | #43 | |
Where did you get such unfounded advice?? I doubt it was from anyone who owns an overdrive equipped vehicle! I would suggest that you find someone who has an overdrive equipped vehicle and go for a ride. It doesn't have to be a Ford pickup. There were many cars with overdrive in the late '40's and through the '50's. You will see how much flexibility and driving pleasure it adds! Installing an overdrive transmission does not radically alter the vehicle! The only visible differences are a small relay on the firewall, a control cable under the dash, a kickdown switch hidden under the gas pedal and some inconspicuous wiring. The crossmember may or may not need altering, but who will notice? I think that when a person wants some how-to advice, we should offer that advice (only if qualified) instead of going off on a Negative Nancy rant with our own personal (often unfounded) personal opinion! |
11-07-2020, 12:22 PM | #44 | |
'52 F-1, EAB flathead |
11-07-2020, 01:50 PM | #45 |
If I were going to do this (OD or T-5) I'd mod the factory cross member by leaving roughly the left "half" of the cross member in place.... because of all the stuff mounted to it that really should
stay in that location. I'd completely remove the right side "1/2." I'd install a second cross member to deal with the transmission tailshaft mount and to tie into the 1/2 OE cross member remaining on the left side, to provide structural integrity for it. That's how you skin that cat. |
11-07-2020, 02:48 PM | #46 | |
Right. It's not exactly rocket science! Well, it might be for some. My point is, If we want overdrive and ask for how-to ideas, there's no need for naysayers to put us down. If they don't want overdrive, (or T-5, or power brakes, etc.) that's fine for them. Or if they don't have any fabrication skills, it doesn't mean that everyone else lacks such skills. Someone who's "been there, done that" is a good source for what works or does not work. Someone who has "never been there, never done that" is not likely a reliable source of helpful information! |
11-07-2020, 03:22 PM | #47 |
I'm in the process of fitting in the R10 overdrive. I've puzzled over how to proceed for a day or two and followed this discussion with interest and I've come to the conclusion that "simple" is best in this case. I'm simply moving the crossmember back a few inches so that the transmission mount fits in front of the crossmember. I only need to bolt a piece of angle iron on the front of the cross member for the mount to sit on. I will reinstall the left part of my old destroyed cross member back in its proper place for the master cylinder and pedal assembly to bolt on to. My cost for this installation will be close to zero except for the bolts and the rubber motor mounts, solenoid seal and rear seal I have on order from Rock Auto. There will be no modifications to the cross member other than a few bolt holes so its structural integrity is intact. I'm still trying to find a 16 spline slip yoke to connect to the drive shaft and this will determine exactly where the cross member will be installed. I may have to cheat a bit and move the motor forward a half an inch or so since I don't want to have to shorten my driveshaft. Regarding total expense - I paid $800 for the transmission. It came with the bellhousing and solenoid. I still need a side shift steering column. If I went for the regular floor shift transmission I would need to find a shifter and regular steering column.
11-07-2020, 03:35 PM | #48 | |
11-07-2020, 03:51 PM | #49 |
Here's a 1949 Mercury OD that was converted to top shift, it can be done.
11-07-2020, 06:40 PM | #50 |
That's quite a bit of ingenuity....
11-07-2020, 07:39 PM | #51 | |
11-09-2020, 01:03 PM | #52 |
A couple of related questions for the experts as I get ready to bolt everything in place. How much space should I allow between the slip yoke and the back end of the transmission? In other words how much does the slip yoke need to move back and forth on the spline when driving? Also is the optimal angle that the motor sits determined when the top of the carburetor is level or does this matter?
11-09-2020, 02:18 PM | #53 |
Stock F-1 engine angle is 3° down at the rear, which puts the carb level.
Do you know your new driveshaft length yet? B_Man_Al and I have done a lot of study on how much the yoke moves on the splines as the rear axle moves up/down, but for stock driveshafts. From resting position, we figure 3/8" inward movement, 3/8" to 1/2" outward. With a shorter driveshaft movement will be more.
11-09-2020, 06:53 PM | #54 |
It boils down the movement in service and the ability to disengage the rear U-joint from the drive flange on the differential. If a person has to fab up a drive shaft, I'd go for the best possible engagement with spline with 3/4" to 1" of total slip without bottoming out. 1 3/4" to 2" of engagement should work but I'd look for as much as I could get and still be safe.
11-09-2020, 07:45 PM | #55 |
B_Man_Al made this drawing of the stock setup
11-09-2020, 07:51 PM | #56 | |
As Ross describes below. Pretty awful alteration for a pick up and expensive too. As to who advised me? Well only the this country's premier and foremost expert on Ford Trucks of this vintage is all! Just a regular "no-body" LOL!! Personal opinions is all Im writing down here, nothing more Mr. 40 Delux. |
11-09-2020, 08:08 PM | #57 |
Lots of good stuff on here about this conversion. Another option to get a little more speed is putting a 3.54 R&P in the Dana 44. It will get you a few more mph. That option isn’t cheap either though.
JB |
11-23-2020, 10:10 PM | #58 |
I finally finished installing the motor and R10 overdrive. I had some difficulty finding a 16 spline yoke but found a new Powerglide one last week. It fits perfectly and the drive shaft turned out to be the correct length also and is in place with new u-joints. I still need to find a side shift steering column but I think I have a lead on one about two hours away. Any ideas as to what I should expect to pay for a steering column without a steering wheel? I also need to still find a clutch pedal.
The brake MC is attached to the crossmember which is mounted 3.5" back but will need a rod extension to reach the brake pedal. The clutch/brake assembly will attach to the short section of crossmember which is in the original position. There is plenty of space for the solenoid. Tomorrow I plan to start replacing the king pins, the brake shoes, brake lines and hoses and shocks. |
11-23-2020, 10:35 PM | #59 |
I put a side shift in my F2 and just used part number 3509 from a 1950 car and
installed it on the pickup steering gear. |
11-23-2020, 10:36 PM | #60 |
double post
Thread Tools | |
Display Modes | |
