08-04-2020, 12:49 PM | #21 |
Re: Annoying rattle.
Mine was also spark and throttle rods
Sent from my SM-G960U using Tapatalk |
08-04-2020, 02:09 PM | #22 |
If my A didn't have a rattle somewhere, I'd be worried that all the parts fell off.
08-04-2020, 06:13 PM | #23 |
Driving my modern today we had an annoying rattle, it was some change under my metal coffee cup!
08-04-2020, 07:20 PM | #24 |
I found a rattle from the crank hole cover. A little silicone sealer will stop the rattle but still allow you to easily open it if needed. Good luck, rattles have been chased unsuccessfully for years.
08-05-2020, 01:33 PM | #25 |
Check prop rod brackets, mine was loose causing a rattle. Added washers so they would not bend in, found out about possible rattle problem here on ford barn....
08-05-2020, 03:23 PM | #26 |
