Old 08-07-2020, 08:40 PM   #1
Wilf55
Default Carb identify
Can anybody identify this carb. It has 4 screws holding it together
File Type: jpg 7AD5EA93-F27A-48A5-91B9-964C8208CF12.jpg (65.6 KB, 127 views)
File Type: jpg 454B77DD-DF56-4E82-A657-ED440411F587.jpg (64.9 KB, 129 views)
Wilf55 is offline   Reply With Quote
Old 08-07-2020, 09:14 PM   #2
larrys40
Default Re: Carb identify
It is a marvel scheibler sold by western auto, sears, etc back in the aftermarket replacement days. Decent carbs but not typically any parts available for them .
Larry
larrys40 is online now   Reply With Quote
Old 08-07-2020, 10:05 PM   #3
1955cj5
1955cj5's Avatar
Renner's corner has rebuild kits...
https://rennerscorner.com/carburetor.html
scroll down to RC-9590 AL
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-08-2020, 09:52 AM   #4
30 Closed Cab PU
I believe Jim Bullock rebuilds them.
https://jmacarbs.com/
Old 08-08-2020, 09:56 AM   #5
Wilf55
Thanks very much. ����
Old 08-08-2020, 09:56 AM   #6
Wilf55
Old 08-09-2020, 07:36 AM   #7
RonC
RonC's Avatar
Larry
I’ve been told Ford sold these too as replacements before the Tillotsons
RonC is offline   Reply With Quote
Old 08-09-2020, 09:18 AM   #8
wmws
A very good carburetor in my opinion. I have one on my car and I like it better in all respects over the Zenith.
wmws is offline   Reply With Quote
Old 08-09-2020, 09:22 AM   #9
30 Closed Cab PU
Just bought a Marvel, should be here fairly soon. Is it a direct swap for a Zenith? Gas line, GAV/Choke rod, Throttle rod all line up and correct length?
Old 08-09-2020, 09:33 AM   #10
Purdy Swoft
Purdy Swoft's Avatar
The Marvel carburetor was a popular replacement carburetor for the model A and was a direct replacement part .
Old 08-09-2020, 10:03 AM   #11
wmws
The gas line must be adjusted a little. I made up a new gas line from a length of hydraulic brake line. The GAV and throttle are OK.
Old 08-09-2020, 10:07 AM   #12
GPierce
GPierce's Avatar
The only problem according to Jim Bullock is there are no replacement floats available.
GPierce is offline   Reply With Quote
Old 08-09-2020, 10:07 AM   #13
30 Closed Cab PU
I do not have the knowledge/tools to do that, would prefer to purchase. Anyone know where I can purchase a Fuel Line for a Marvel for a late 30 CCPU (glass fuel Strainer bowl)?
Old 08-09-2020, 10:36 AM   #14
30 Closed Cab PU
Thanks for the help all, I finally found the info, different line not needed just needs reforming., but need an adapter fitting where the gas line fits to the Marvel.
http://rennerscorner.com/carburetor.html
item RC-9288-FLA
Old 08-09-2020, 10:36 AM   #15
JBill
The fitting from the gas line to the carburetor fuel inlet is a little different from either Zenith or Tillotson.
JBill is offline   Reply With Quote
Old 08-09-2020, 11:48 AM   #16
Sunnybrook Farm
Sunnybrook Farm's Avatar
Attached are photos from the 1948 Sears catalog showing the carburetor and the price for the core Zenith that they want in exchange. Not sure what they did with the Zeniths that they got as they don't seem to be selling them in the catalog.
Sunnybrook Farm is offline   Reply With Quote
Old 08-09-2020, 01:28 PM   #17
[email protected]
modela@aol.com's Avatar
I thought you might be interested in reading this web page discussion on FB from 2015:
https://www.fordbarn.com/forum/showt...ferrerid=16136
modela@aol.com is offline   Reply With Quote
Old 08-09-2020, 05:34 PM   #18
30 Closed Cab PU
bought the carb from Jim Bullock, so emailed him, was amazed when I got a reply today/Sunday. His carbs are already set up to be a direct swap for teh Zenith. So no special gas line fitting or GAV Needle driver required - plug and play.
Old 08-10-2020, 12:14 AM   #19
1930-Pickup
Marvel-Scheibler is a good carb company.
They were used for many decades for light aircraft applications.
I don't see Tillys or Zeniths flying around...just saying
I'm using a 1932 Zenith (for Model B) right now, otherwise I would go for the M-S.
1930-Pickup is offline   Reply With Quote
