Old 06-08-2021, 10:59 AM   #21
Bored&Stroked
Bored&Stroked's Avatar
Default Re: spark plug recommendation
You'll find that with most of today's gas, that plugs don't "color like they used too". It is difficult to achieve a nice chocolate brown color . . . just never seems to happen for me. I tend to see colors that are a much lighter brownish/grey when the mixture is right.
As RoTo mentioned, you should do a test on the highway . . . is the only real way to do it. If you drive around, then come to stops and idle the engine . . . you'll find they almost always look too rich. So, you can't check the plugs after you go home - you'll not have accurate coloring . . .
Or, put some O2 sensor bungs in your exhaust and use a meter to tell you what is really happening.
Old 06-08-2021, 05:55 PM   #22
3twinridges
3twinridges's Avatar
I had a similar issue at cruise speed, good advice on the plugs. In my case, the driveshaft was severely out of balance. Had a driveline shop balance it and all good.
JB
3twinridges is offline   Reply With Quote
Old 06-09-2021, 11:14 AM   #23
farmertom
farmertom's Avatar
anyone using autolite 386s? seem to work fine in my orig 37 flathead.
farmertom is offline   Reply With Quote
Old 06-11-2021, 10:37 PM   #24
svmsr1044
Ronnie, I’m curious why you recommend a larger plug gap for 12 volts. Is the secondary voltage of a 12 volt system higher than a 6 volt system?
svmsr1044 is offline   Reply With Quote
