Old 04-11-2021, 10:30 AM   #1
Digger
Digger's Avatar
Default ‘34 kick panel material
Anyone know where I can get the proper hardboard for the 33-34 kick panels? I have the pattern, but not the material. Appreciate any leads. Have a great Sunday.
Digger is offline   Reply With Quote
Old 04-11-2021, 11:10 AM   #2
Kube
Kube's Avatar
Default Re: ‘34 kick panel material
You can purchase picture frame mat board at any decent hobby store. It comes in a zillion colors and is about the same thickness as the authentic panels.
Around here, Hobby Lobby has the best selection. Do you have a Hobby Lobby in your area?
Old 04-11-2021, 11:32 AM   #3
Digger
Digger's Avatar
Oh, great idea, I will check it out!
Old 04-20-2021, 05:18 PM   #4
Dennis Mielke
One of the parts suppliers has fiberglass kick panels. Don't remember who but found out that open cars are different than closed cars. If you want I'll try to see who I got them from
Dennis Mielke is offline   Reply With Quote
Old 04-20-2021, 06:32 PM   #5
Digger
Digger's Avatar
Macs sells black fiberglass kick panels, don’t like them. Thanks.
Old 05-22-2021, 06:39 PM   #6
Digger
Digger's Avatar
So circling back on this, finished the install today of a pair of kick panels in a 34 coupe. Got the picture frame mat board at Michael’s. The color was spot on, just right, nice dark brown. Sorry I forgot to snap a photo, but over all it came out great. A few things to note: it is half the thickness of the proper kick panel board, so you might want to use spray glue and make a double thick panel to start with. Also, it seems to scuff easier than a correct board, kinda soft, but looks great. Also when you cut it, the core edge is bright white, so you see that edge, unless you can really force the edge behind the vertical welting. Next time I get the car out again, will take some pics.
Old 05-23-2021, 07:57 AM   #7
Kube
Kube's Avatar
Thanks for letting us know how this worked for you. The white edge things I'd failed to mention previously as well, on the '39 & '40's I restore, that edge is covered by the retainer. Perhaps a marker in a matching color would serve you well?
I was able to buy very thick board at Michael's Hobby. It's been a while so perhaps they no longer sell the "thick stuff".
Regardless, glad you found a good solution.
Old 05-23-2021, 10:57 AM   #8
Digger
Digger's Avatar
Kube, I did try the marker idea, first off have to be very steady handed and not slip and draw a big line onto the board! It worked ok but I should have shopped around for a lighter shade of brown, overall I am happy with it.
Old 05-23-2021, 09:40 PM   #9
banjoQ
banjoQ's Avatar
I picked up on this thread in the beginning. I had tried to find the original material door cards and kick panels. The fiberglass/ plastic ones did not work for me. Kube’s post that mentioned Hobby Lobby got me thinking. Found that they a wide selection of matting material. They have several different weights( thicknesses) which include a heavy one that worked fine. I used black and found it to be dyed through, no core. Six bucks a sheet, three sheets does a truck fine. It’s not perfect but it’s pretty good.
banjoQ is offline   Reply With Quote
Old 05-24-2021, 11:30 AM   #10
Mike34
Mike34's Avatar
Great post!!!
I'm in the middle of restoring my '34 5-Window and I have a '34 pickup waiting for some future love. I do not plan to use the plastic either but I also don't have a pattern for the kick panels. Digger, would be kind enough to send me a paper tracing of the kick panels?
Thanks, Mike
Mike34 is offline   Reply With Quote
Old 05-24-2021, 12:47 PM   #11
Digger
Digger's Avatar
Yes I can do so, will send you a PM
Old 05-24-2021, 04:28 PM   #12
FlatheadTed
FlatheadTed's Avatar
, Having worked with Matt board in the past this sound like a good choice maybe you could spray it with a lacquer rattle can Matt clear to toughen it up on both sides ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 05-26-2021, 04:02 PM   #13
Wrenchead
We’re you able to cut the mat board with a razor knife?
Wrenchead is offline   Reply With Quote
Old 05-26-2021, 04:44 PM   #14
Digger
Digger's Avatar
Yes, has to be a brand new blade and a super steady hand and/or use the old panel as a fence. My hand was semi steady, and my vision sucks, so I had to put my face right next to the blade!!
Old 05-27-2021, 12:21 PM   #15
dmar836
The matte spray is a good idea. I have done that before to good effect.
D
dmar836 is offline   Reply With Quote
Old 05-27-2021, 04:24 PM   #16
Digger
Digger's Avatar
Of course do a test on a scrap piece first
Old 05-29-2021, 05:55 PM   #17
Digger
Digger's Avatar
Photos
File Type: jpg 3857F545-37EF-4EF5-AB16-C5D9F852C250.jpg (67.2 KB, 58 views)
File Type: jpg 8536DDAA-D546-4F40-8334-3E8D91408F96.jpg (70.5 KB, 52 views)
Old 06-01-2021, 09:36 PM   #18
FlatheadTed
Digger,the pictures look pretty good ,
