Old 12-31-2020, 09:19 PM   #1
700rpm
700rpm's Avatar
Default Taillight grounding
I am going to add a RH taillight to my sedan. Do the mounting bolts ground it, or does that happen somewhere else in the wiring?
Ray Horton, Portland, OR
Old 12-31-2020, 09:52 PM   #2
Big hammer
Default Re: Taillight grounding
Tail light housing to stand to fender to the body !
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 12-31-2020, 10:53 PM   #3
700rpm
700rpm's Avatar
Thanks. That’s sorta what I thought, but I needed confirmation. Happy New Year!
Old 12-31-2020, 10:57 PM   #4
Flathead
Flathead's Avatar
As long as they aren't fiberglass fenders.
Flathead is offline   Reply With Quote
Old 12-31-2020, 11:15 PM   #5
CarlG
CarlG's Avatar
If it's in doubt as to whether or not I get a good ground, I typically will run a separate ground wire whether it needs it or not.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-01-2021, 12:24 AM   #6
McMimmcs
McMimmcs's Avatar
Wire is cheap. Run a separate ground.
McMimmcs is offline   Reply With Quote
Old 01-01-2021, 12:47 AM   #7
700rpm
700rpm's Avatar
From where in the light?
Old 01-01-2021, 12:56 AM   #8
J Franklin
J Franklin's Avatar
Ground the socket body.
Old 01-01-2021, 08:01 AM   #9
Big hammer
Solder a ground wire to the outside of the socket and run it though the wiring loom and to a good ground. Why didn't Ford run dedicated grounds ? To save a nicklem!
BTW when I mounted the right hand light I measured 6 times and it didn't look right before drilling holes, I then used a straight edge across both faces of each light and then when it looked right I drilled the holes. But I can hang pictures without a level!
Old 01-01-2021, 08:05 AM   #10
Big hammer
Or powder coated stand or to much paint, it would be best to run a ground wire from outside of the light socket through the wiring loom back to the chassis.
