Old 11-05-2020, 10:50 AM   #1
1931flathead
Default Ford holley 94 carbs
I'm trying to make secondary carbs I can not get the butter flyes to closed tight
Have new shafts and secondary plates anything I do they have light around them
1931flathead is offline   Reply With Quote
Old 11-05-2020, 12:42 PM   #2
drolston
drolston's Avatar
Default Re: Ford holley 94 carbs
Lightly sand the edges of the butterfly plates to slightly round off the sharp edges and remove any burrs. That may improve tight closure and will reduce the chances of sticking at the closed position. Be sure the butterfly plates move freely within their slots in the throttle shafts. Deburr slots as needed. Install the plates in the shaft but leave the screws loose. Hold both of the actual plates themselves tightly closed as you tighten the screws. Do not tighten the screws very hard. A loose plate would be fine, as long as the screws do not fall out. That should get you good closure and no binding. Be very gentle in dimpling the throttle plate screws; A tiny distortion is enough to keep the screws from falling out
Old 11-05-2020, 01:04 PM   #3
Charlie ny
31,
I build a lot of 94's and use the Speedway extended shafts.....what I have found is the 6-32 Phillips head screws included with the shafts actually distort the shaft because the chamfer under the head is not concentric with the threads, I use only factory issue brass screws and make them tight plus apply Locktite. It is also my
experience that the non factory throttle plates ,such as you have described, are of varying quality. My preference here is factory only throttle plates. This is only my opinion.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 11-05-2020, 02:20 PM   #4
1931flathead
I only had two good plates they seem to do the same thing I didn't have screw in mine
I might junk the bases and buy new ones so I don't have problems
Old 11-05-2020, 02:33 PM   #5
KiWinUS
KiWinUS's Avatar
Send carbs to Charlie NY To rebuild carbs. You will not regret it.
Old 11-06-2020, 10:49 AM   #6
1931flathead
I can buy these and have less money whin I'm done
Old 11-06-2020, 11:11 AM   #7
scicala
scicala's Avatar
Originally Posted by Charlie ny View Post
31,
Charlie ny
Charlie, do you have a source for the original type brass throttle plate screws, or do you just have a stock pile of NOS ones ? Thanks.
Sal
Old 11-07-2020, 10:40 AM   #8
flatrod
flatrod's Avatar
I see those are 1 1/4 throttle plates. I answered on the other forum about the shafts. Everything I have bought from Speedway and Charlie Price seems to be the same. I don't know if Charlie is making for Speedway or is buying from Speedway. Anyway to fix my problems I just had to drill the top side of the shafts so the screw went in and started threading to the bottom side, not the top. Try putting your screws in without the plates. If they have to screw in the top side, you will need to relief that so they just thread into the bottom haft of the shaft. Hope that make sence...
flatrod is offline   Reply With Quote
Old 11-08-2020, 10:57 AM   #9
1931flathead
I have tried the old plates seem to be the same I left the screws a little lose didn't not change much I will try to do what you did to see it helps
