10-20-2020, 10:11 AM | #1 |
Generator Charging
When my '31 slant windshield is at idle the Ammeter is at zero. When I raise engine speed it goes to 10 and even 20 amps charging. When I move center brush up or down idle amps do not change, reads zero. Is my gauge bad? Could i have wires reversed on brushes? Gen motors when wires jumped.
10-20-2020, 10:35 AM | #2 |
Re: Generator Charging
You mention "idle amps". At idle, the generator cut out has opened and broken the contact, so you do not get any charging showing at idle. You would adjust your charging rate at a higher RPM, when the cut out closes again, moving the brush as you mentioned.
10-20-2020, 01:37 PM | #3 |
Good info. Thank you. Will try again at fast idle.
10-20-2020, 11:34 AM | #4 |
If you were to read the instruction manual you would see that the car should not show a charge at idle or with the headlights on
10-20-2020, 12:05 PM | #5 |
You failed to mention the fast idle charging rate after adjusting the third brush. Set it to a few amps if you drive mostly during the day, a little higher for at night. It really shouldn't be set for more than 10 amps.
10-20-2020, 05:59 PM | #6 |
10-21-2020, 08:02 AM | #7 | |
Pat |
10-20-2020, 07:01 PM | #8 |
No, its not normal. When I say fast idle I mean around in the 1000-1500 RPM range.
The charge rate should not go that high. |
10-20-2020, 08:26 PM | #9 |
Where should the needle be at normal driving speed with the lights on?
10-20-2020, 09:02 PM | #10 |
At or below 0
10-20-2020, 10:51 PM | #11 |
Duffy, Sounds like you may be getting confused about how to set the third brush and you might need to start over. A good rule of thumb is to determine a starting point from which to adjust the brush in either direction. I always start by looking into the open slots in the rear of the generator and setting the third brush so that it looks to be equally distant in between the two other brushes. After doing so, get in the car, start it, and fully advance the spark lever. At idle, the ammeter may read zero or maybe about 2 amps at the most. Do not be concerned by this. Now, rev up the engine with the accelerator pedal. The ammeter should really go no higher than about 8 amps with the engine revved up. If it is higher or lower than that, now you have a starting point from which to move the third brush, in small increments, in either direction ............ toward the engine side of the generator for less charge .............. toward the fender side of the generator for more charge. Remember ........... SMALL INCREMENTS .............. until you get it to where it puts out no more than 8 amps with the engine revved up. If at any time during the adjustments you see a major spike in the charging rate, it might be time for closer inspection and repair of the generator itself. It may take several attempts to get the adjustment correct. Be patient. But, start with a reference point you can always go back and start over should you get flustered or frustrated. Good Luck, Bob Bader
10-21-2020, 10:12 AM | #12 |
I use the Fun Projects voltage regulator . I adjust the third brush for a ten amp maximum charge . The voltage regulator controls the amount of charge up to that point . The regulator takes the place of the cut out and prevents the generator from overcharging the battery and boiling the acid . Before installing the voltage regulator I would turn on the head lamps to reduce the charge rate when I would smell the acid boiling .
10-21-2020, 06:00 PM | #13 |
Duffy.......what shape is your battery in, water level, terminals ?
10-21-2020, 07:40 PM | #14 |
If ya drive your car daily 0 is good. For us occasional drivers 1 amp with the lights off seems to be the sweet spot. Of course I do have a hand crank though...
10-22-2020, 10:35 AM | #15 |
If you can't set the output low enough [ 2-4 amps lights off at fast idle/ slow cruise speed] then I'd recommend checking voltage output. These generators can produce 20+ volts if there is a poor connection/ground somewhere. Or, there can also be a generator problem.
10-22-2020, 11:01 AM | #16 |
If the fields are connected backwards , the generator will still charge but moving the third adjustable brush will have no effect on the charging rate .
10-23-2020, 10:37 AM | #17 |
1931 should have the coil connected directly to the generator at the firewall so the ammeter reads only battery current. The ammeter will read 0 until the cutout closes, after which you should expect >6 amps to replenish the battery after starting but should drop to 1 amp or so after a minute or two. A weak (shorted cell) battery won't charge to full voltage and will keep drawing a higher current and heat up. You may need a new battery.
10-23-2020, 02:14 PM | #18 |
Charge rate shouldn't change with an original cut-out. If a regulator is installed then it will change.
10-24-2020, 09:41 AM | #19 |
