Old 09-12-2021, 02:29 PM   #1
ursus
Default Rust Stains on Stainless Steel
My 1931 headlight and tail light buckets have heavy rust stains where the non-stainless steel fasteners were located. I tried some mild rubbing compound which has had little effect on the stains.
I may try to soak them in one of the chelating solutions such as Evaporust or WD-40 Rust Remover, but am curious what these effect these products will have on the stainless steel. I do know that they will slightly darken regular steel. Any thoughts or experience with this? Thanks.
ursus is offline   Reply With Quote
Old 09-12-2021, 02:38 PM   #2
tinkirk
tinkirk's Avatar
Default Re: Rust Stains on Stainless Steel
Some Toilet cleaner like snow bowl might work
tinkirk is offline   Reply With Quote
Old 09-12-2021, 02:47 PM   #3
51504bat
51504bat's Avatar
Try Coke and aluminum foil.
Old 09-12-2021, 03:17 PM   #4
McMimmcs
McMimmcs's Avatar
I spray with WD-40 and scrub with a tooth brush. I’ve had great results Wayne
McMimmcs is offline   Reply With Quote
Old 09-12-2021, 05:08 PM   #5
nkaminar
nkaminar's Avatar
Barkeepers Friend, available in grocery stores, removes rust. Then polish with any of the metal polishes. I have had good luck with SIMICHROME POLISH, part number M-6067 at Snyders. https://www.snydersantiqueauto.com/
If the rust is really deep you may have to use a buffing wheel.
Old 09-12-2021, 05:35 PM   #6
Oldbluoval
Oldbluoval's Avatar
Best polish I’ve found is Wenol.
But some of the above ideas of getting rid of bad stains might be in order first
Oldbluoval is offline   Reply With Quote
Old 09-17-2021, 08:52 PM   #7
Gufshoz
Gufshoz's Avatar
I burnished my rusty bumpers and instrument panel with water-wetted aluminum foil. A little elbow grease and follow up waxing and you'll be amazed.
Gufshoz is offline   Reply With Quote
Old 09-19-2021, 07:01 AM   #8
eagle
eagle's Avatar
In the laundry section of your grocery store you will find Whink Rust Remover. Will completely remove the rust stains, just about like magic. https://www.amazon.com/Whink-Product...91099188&psc=1
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 09-19-2021, 12:25 PM   #9
Terry, NJ
Terry, NJ's Avatar
You might try a product called "Iron Mike or Iron Ike, Or Iron Out" or a few other names. It is a Sodium Bisulphate (?) cleaner, IIRC. Good for sinks, tubs and drains where Iron is a problem. It's good for "Tramp Iron" on Stainless steel too. Never, ever use laundry bleach on iron stains. The products mentioned arr available in supermarkets, plumbing supplies, and hardware, and Big box stores.
Terry
Terry, NJ is offline   Reply With Quote
Old 09-25-2021, 01:14 AM   #10
DD1930DD
SOS Pads work too
DD1930DD is offline   Reply With Quote
