Old 05-14-2021, 04:50 PM   #1
tudor 28
Default Rear hub sleeved wheel bearing faliure
I had my '28 rear hubs sleeved with the repair kit. It now uses '36-'48 Ford rear wheel bearings ?
If you've had this done did you have any problems with new bearing failure of either cage end because they were not hardened ? Seems as though the problem is not the rollers but the ends (thrust bearing).
Also if you've had it done with no problems who supplied the bearings.
tudor 28 is offline   Reply With Quote
Old 05-15-2021, 07:02 AM   #2
jwmckenzie
Default Re: Rear hub sleeved wheel bearing faliure
Have you had a failure?
jwmckenzie is offline   Reply With Quote
