02-16-2021, 11:48 AM | #1 |
Edelbrock head identification help
I found a set of Edelbrock heads in my dads parts pile. Block lettered, aluminum, center water inlet. They both have a “9” stamped into top side of each head at the base of the water inlets. Also have “DB 142” stamped into the inside edge (intake side). I know “9” means 9:1 compression, right? It what does “DB 142” mean? Also found a Grancor 2x2 aluminum intake. It doesn’t have generator mount on it.
02-16-2021, 02:19 PM | #2 |
Re: Edelbrock head identification help
Welcome to the Barn, that is a cool find. Sorry, I can't answer your question about the markings.
02-16-2021, 03:09 PM | #3 |
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
