Old 06-03-2020, 05:05 PM   #1
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
Default Easy way to pump gas out of gas tank
I got two cars that I half to pump all the gas out so I can wash out the tanks. One is the 56 Tee Bird and the other is a 63 Split Window Corvette. Here what I did I went to Tractor Supply and bought a Battery pump that takes two flash light battery. Works super in a few minutes the gas tank was dry. So if you ever have this problem that the way to go. Yesterday I ordered a heater motor for the Tee Bird and it came today. I ordered the parts from Hill's in southern Ohio
Old Redneck is offline   Reply With Quote
Old 06-05-2020, 02:01 PM   #2
Jwawhite
Jwawhite's Avatar
Default Re: Easy way to pump gas out of gas tank
Hand pump from Harbor Freight and Jersey Cans. Hand pump needs screw clamps to stop the hoses from slipping off during pumping. Once the gas flows it keeps going w/o pumping.
Quick and easy.
Jwawhite is offline   Reply With Quote
Old 06-05-2020, 03:42 PM   #3
58Yeoman
58Yeoman's Avatar
Ya gotta be old school and suck on the hose, hoping that you don't get a mouthful of gas. If you do, you've been initiated.
58Yeoman is offline   Reply With Quote
Old 06-05-2020, 04:06 PM   #4
Dobie Gillis
Dobie Gillis's Avatar
We used to call that an Oklahoma credit card...
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 06-07-2020, 09:07 AM   #5
Bob/Pa
Bob/Pa's Avatar
Back in 50's we called it the Pennsylvania FILLUP, always carried a hose.
Bob/Pa is offline   Reply With Quote
Old 06-07-2020, 09:33 AM   #6
Old Redneck
I always got a mouth full when sucking gas from a car. Just don't care for that tast. I was surprise on how fast that worked.Now you know the easy way. Tractor Supply for the battery pump.
Old 06-07-2020, 11:22 AM   #7
50fordcoupeman
50fordcoupeman's Avatar
Put your siphon hose in the tank, the other end in your gas can, put the tip of your air hose along side it with a rag stuffed around both of them for a seal and give a it a shot of air. The gas will be coming out the siphon hose so be ready.
50fordcoupeman is offline   Reply With Quote
Old 06-08-2020, 01:30 PM   #8
grumppyoldman
grumppyoldman's Avatar
I generally remove the plug from the tank and let it drain in a large cut off plastic drum. Al
grumppyoldman is offline   Reply With Quote
Old 06-08-2020, 01:43 PM   #9
Hot Rod Reverend
Hot Rod Reverend's Avatar
ditto here - not sure why you would need to pump gasoline out. Maybe if you were scavenging for fuel? I would think that if you used the drain you would get more of the junk out of the tank than pumping... but what do I know lol I learn something new all the time on these old Fords.
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 06-08-2020, 06:30 PM   #10
50fordcoupeman
I filled my tank full and then drained out half the gas in a can. I was checking the accuracy of a newly installed fuel gauge...............
