Old 12-08-2019, 04:52 PM   #1
whb52ford
whb52ford's Avatar
Default Ford Starter
I see ton of used 6v starters for tractors. Does anyone know if a tractor starter will work in a car? How would I cross reference it. Can I cross a truck to car starter? thx
whb52ford is offline   Reply With Quote
Old 12-08-2019, 05:29 PM   #2
al's28/33
al's28/33's Avatar
Default Re: Ford Starter
Tractor starters are a different set-up than autos...… I THINK …… and car starters can be swapped for trucks too.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 12-08-2019, 07:56 PM   #3
Bob C
What year 6cyl or V8?
Old 12-08-2019, 09:48 PM   #4
whb52ford
whb52ford's Avatar
6cyl, std tranny, 52. Two different shaft lengths
Old 12-08-2019, 09:58 PM   #5
19Fordy
19Fordy's Avatar
I think the 6 cylinder and 8 cylinder starters are not interchangeable.
Old 12-09-2019, 06:34 AM   #6
whb52ford
whb52ford's Avatar
My friend had an 8 automatic and my starter did not work in his car. I don’t know if it was 6 vs 8, or auto vs std
Old 12-09-2019, 08:59 AM   #7
L-head
An 8N tractor (6V) uses the same starter as a 60hp flathead. Your local New Holland/Ford tractor dealer should be able to supply parts for them. Their parts books ever carry the 52-part numbers. Even the starter drives work on 60hp engines.
L-head is online now   Reply With Quote
Old 12-09-2019, 09:00 AM   #8
big job
big job's Avatar
My question is what is the difference between automatic and standard V8 starter I only
have seen one automatic it was a new 1951 (Victoria i think). My reason is couple yrs
ago we picked up a 1953 complete EAB with automatic & haven't got to it yet .. sam
big job is offline   Reply With Quote
Old 12-09-2019, 09:21 AM   #9
whb52ford
whb52ford's Avatar
As I remember, and it was years ago, it had to do with the length of the shaft. Mine was to short or to long. I can't remember. I think the bolt pattern was the same, but that was a long time ago. His starter was at the shop getting rebuilt and he wanted to start his car, so I took mine out, but it didn't work.
Old 12-09-2019, 10:16 AM   #10
51504bat
51504bat's Avatar
Automatic V8 starters are different than standard V8's
Old 12-09-2019, 12:31 PM   #11
flatheadmurre
flatheadmurre's Avatar
If i remember right the fordomatic/mercomatic starter has a different front plate with 3 bolts one tab sticking out from it with an extra bolthole.
And a 9 tooth sprocket.
Old 12-09-2019, 12:47 PM   #12
FritzJr
FritzJr's Avatar
Starter shaft is longer for the flathead V8's with automatics as compared to V8's with standard transmission.
FritzJr is offline   Reply With Quote
Old 12-10-2019, 10:30 AM   #13
whb52ford
whb52ford's Avatar
I wonder if the shaft length is the same deal as the V8. Will the shorter one work on a 6 std?
Wonder if they are both 9 tooth
I do know the V8 has an L shaped clip that the 6 does not have
Old 12-10-2019, 09:09 PM   #14
Bob C
I looked in the Hollander Interchange and it shows 51-53 pass 8 cyl automatic, 52-53 pass 6 cyl overhead, 52 truck 6 cyl overhead, 50-53 Merc automatic.
Starter catalog shows #3108 5 3/16" shaft ( which I think is the short one) one mounting ear. See link for picture. http://www.wilsonautoelectric.com/Pa...7-e690abfc15fd
Bob
Old 12-10-2019, 09:18 PM   #15
whb52ford
whb52ford's Avatar
I'm beginning to think the difference is not 6 vs 8 but auto vs std.
Did it show what std transmissions interchange.
Old 12-10-2019, 10:11 PM   #16
Bob C
For the 1952-53 6 cyl it only showed the one starter.
Old 12-11-2019, 07:56 AM   #17
whb52ford
whb52ford's Avatar
It’s funny because the 52 and 53 Ford parts book do not show a starter for 6 cyl std. I know they made one because I have one!
Wondering if I could get an end cap for my car and put on a tractor starter?
Old 12-11-2019, 10:24 AM   #18
rotorwrench
rotorwrench's Avatar
It depends on the parts book. Most Fords used the same starter for years until they started bolting them on with ears off the rear bearing plate. A lot of parts internally were still the same. The 9N and V8-60 as well as the 8N all used the same starter and they bolt on same as the early 221/239 V8 but they have a different armature and rear plate. The only difference between the flathead V8 starter and the two flathead 6 starters was the little bracket that attached to the oil pan. The later overhead valve tractors have bolt on flange starters like the automatic transmission cars & pickups. The armatures are a different part number though.
Old 12-11-2019, 10:46 AM   #19
L-head
2N,9N,8N use the same starter. The 60hp flathead uses the same starter and starter drive. The starter drive on tractors and 60hp engines attach with a pin and not set screws and a woodruff key like the other V8 cars and trucks.
Old 12-11-2019, 12:51 PM   #20
whb52ford
whb52ford's Avatar
Can anyone give me the correct starter part number for a 52 Ford car 6 cyl, std tranny?
