11-26-2021, 11:31 AM | #1 |
A couple of 8BA engine questions
I pulled the original 2 bbl manifold in preparation for the 4 bll intake for the fuel injection I am installing, and noticed one intake runner was rusty. I also noticed some of intake bolt holes had water in them.
My question, do the intake bolt holes extend into the water jacket? If so, I imagine there should be thread sealant used when installing the manifold. I rubbed the rusty intake runner and it appears to just be surface rust, the back of the valve looks clean as does the stem. Hopefully not a cracked block and it's just sucking water from the bolt hole and under a faulty gasket. Last thing, should I use Permatex Form-a-gasket on both surfaces to help seal the intake? Your thoughts? Pics of the rusty port and the port next to it. Cheers
1949 Ford F-47 with a '51 8BA Flatty, GM TBI fuel injection system, and a grey shop cat, Spot. |
11-26-2021, 11:51 AM | #2 |
Re: A couple of 8BA engine questions
I like the idea of just using grease. If you use sealer on both sides it will be very difficult to remove in future. You can check both surfaces with a straightedge .
11-26-2021, 03:27 PM | #3 |
Intake bolts do not go to any water.
11-26-2021, 03:56 PM | #4 |
Okay, just heading back to the shop to investigate further. I'll blow out the holes and poke a wire down to see if they all bottom...hopefully the water was just leftover from the rain we had a few weeks ago...but why the water damage on intake port cylinder 5? More investigation required.
Thanks! Cheers
11-27-2021, 10:48 AM | #5 |
You might want to pressure test this block!!!!
G |
11-27-2021, 02:41 PM | #6 |
11-27-2021, 03:00 PM | #7 | |
I'm cleaning it all up and getting ready to mount the Fenton today. Thanks all. Cheers
