12-24-2020, 02:56 PM | #1 |
39 radiator removal
I'm removing the radiator from 39 deluxe. Do I need to remove the inner fender braces and the horns to get it out? Thanks in advance
12-24-2020, 08:48 PM | #2 |
MEMBER EMERITUS
Re: 39 radiator removal
Horns shouldn't need to be removed.
The 2 brackets that run from the inner fender to the radiator will have to be removed ( if the car still has them attached ) You may also want to take out the fan for ease of access. |
12-24-2020, 09:07 PM | #3 |
Braces have to be removed.
12-24-2020, 09:12 PM | #4 |
Braces (Part number 8046) have to be removed. You'll have to remove the fan assembly also so as not to damage your radiator. I altered mine but they look like this photo.
Please excuse double post. Last edited by 19Fordy; 12-24-2020 at 09:50 PM. |
12-25-2020, 07:48 AM | #5 |
thanks, braces look easier to remove/replace than the horns. Ernie
12-25-2020, 10:50 AM | #6 |
