Old 07-07-2022, 09:13 AM   #1
KiWinUS
KiWinUS's Avatar
Default Brake rods
G’day Model A team. I’m a V8 guy but have a really cool 29 A I’m working on. I may need a lot of help but for now what direction do the brake rod clevises go? Center of car or at the backing plate actuator’s? Or front one way and rear the opposite as they are now. Thanks for your help in advance.
Cheers
Tony
Old 07-07-2022, 09:46 AM   #2
burner31
burner31's Avatar
Default Re: Brake rods
The adjustable clevis attaches to the brake actuating arm on the backing plate, both front and rear
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 07-07-2022, 10:01 AM   #3
KiWinUS
KiWinUS's Avatar
Thanks Keith. Much appreciated.
Old 07-07-2022, 11:11 AM   #4
jwmckenzie
I believe the adjustable end always goes forward. The fronts are at the arm that goes unto the backing plate, the rears mount to the center shaft cross shaft.
jwmckenzie is offline   Reply With Quote
Old 07-07-2022, 02:37 PM   #5
MAG
MAG's Avatar
X2 on post 4.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 07-07-2022, 03:15 PM   #6
Ruth
Nope
This is correct, towards the front. I don't believe it would make any difference operation wise, but it would be a bitch to get to if the rear ones were at the backing plate.
Ruth
Old 07-07-2022, 06:26 PM   #7
Synchro909
Synchro909's Avatar
Agreed from me - adjustable end towards the front of the car. That is, at the backing plate for the front brakes and at the cross shaft for the rear ones.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 07-07-2022, 07:35 PM   #8
KiWinUS
KiWinUS's Avatar
Thanks team for all the great info.
Cheers
Tony.
