08-02-2021, 04:00 PM | #1 |
Is This Broken...End Of Cluster Shaft
EDITED UPDATE: THIS POST HAS BEEN SOLVED...THE PART IS NOT BROKEN IT ENDS AS A HALF CIRCLE ON THE CLUSTER SHAFT....I'LL LEAVE UP SO OTHERS MAY LEARN THIS TOO.
I was looking under the car due to another post about transmission seal kit and I see my Cluster Shaft end looks to me to be cracked but then again I can't see how it is because I don't see the other "half". Is it round or is it half moon...I never rebuilt a transmission and didn't notice this before. It's not loose or leaking. Please advise. Last edited by jg61hawk; 08-02-2021 at 04:23 PM. |
08-02-2021, 04:07 PM | #2 |
Re: Is This Broken...End Of Cluster Shaft
Bigger Picture I think
08-02-2021, 04:17 PM | #3 |
If it is not leaking I Would not worry.
John
Welcome each day |
08-02-2021, 04:21 PM | #4 |
Actually I should delete this post... I had the thought to look up the part and Snyder's has a nice view...it ends as a half circle so I'm good. Never was a problem...I'll leave the post in case someone has the same thought...It looks odd because the other shaft is a circle. Thanks John for the fast reply.
https://www.snydersantiqueauto.com/P...earchByKeyword |
08-02-2021, 08:45 PM | #5 |
Tom Endy |
