Old 05-12-2010, 07:23 PM   #1
jchochole
jchochole's Avatar
Default Pic of wiring terminal block
Fellow Lizzie-fans!
Does anyone have a '26 or '27 T with new wiring on the terminal block that works? I got my '27 all wired up and my references used different colors and numbers of the terminals. I need a real-world peek at a color scheme and arrangement. Please send to my email at:
[email protected]
Thanks in advance,
Jim from IL
jchochole is offline   Reply With Quote
Old 05-13-2010, 01:45 PM   #2
agriscience
Default Re: Pic of wiring terminal block
Check out Texas T Parts for a free wiring diagram!
agriscience is offline   Reply With Quote
Old 05-13-2010, 04:33 PM   #3
tmodelman
tmodelman's Avatar
Default Wiring terminal block
Here is a picture and a wiring diagram
tmodelman is offline   Reply With Quote
Old 05-13-2010, 08:24 PM   #4
jchochole
jchochole's Avatar
Thanks very much for taking the time to send both the image and the diagram. I hadn't seen that diagram around- it may well do the trick.
Thanks again,
Jim from IL
Old 05-15-2010, 10:33 PM   #5
Model T Monte
Be careful the aftermarket terminal block will strip if you get very tough on the screws. Guess I was too rested that day.!?
Model T Monte is offline   Reply With Quote
