04-04-2015, 12:55 PM | #21 |
Re: 1934 Ford 3 window vs. 1934 Ford 5 window
As a side question here. Is the rear window regulator the same as one of the door window regulators such as in a Model A, or is it unique only to the rear window?
04-04-2015, 01:34 PM | #22 |
They are similar, but the length of the arm is unique, which can be either shortened or lengthened without a lot of effort.
04-04-2015, 03:01 PM | #23 |
all 3wds. were deluxe, so they had the role down wd. but ,I think the 5wd. standard did not have the role down wd.
04-05-2015, 12:23 PM | #24 |
I notice as usual no evidence or even explantion is forthcoming here - just spew .
I definitely did not help built any new 33-34 coupes nor have I owned or seen all of them . Yes I have been around these long enough to know NOBODY knows all . That said why is it so hard for the non-rolldown believers to show or explain how it was done ? I would like to know as the normal window box is not real adaptable to a glass sealed against the body like a 5w quarter window . Definitely seen 33-34 coupes with fixed rear glass done both nicely and just glued to the lip but nothing done by Ford . Also 33 3w standards are not that rare . The reference in post 19 to a wider than normal rear garnish for a coupe sounds to me like a sedan delivery one . I really am curious about this as I am not aware of any FACTORY DONE EXAMPLES and if valid I would like to know how they did it . David J |
