09-14-2022, 06:40 PM | #21 |
Re: Optima 6V
I used spacers on top of the hold down and left the battery sitting on the bottom of the tray. I did have to cut the corner of the mounting tab that is next to the center cross member. The tabs could be jigged in a better position before welding, that's for sure. The one picture above is correct, welded tabs on opposite corners.
To bad my tabs were welded in the center. QC, ... Pft! Regards Bill |
