07-31-2021, 06:58 PM | #1 |
Kwik-Lift
Has anyone bought one of these Kwik-Lift? Seems like it could be a good product to get the car off the floor (20" high) to do under the car work. Seems that it can be folded up and than drive the car over it while not in use. I would like to hear from anyone that has bought this product good or bad.
Thanks for your time! |
08-01-2021, 11:07 AM | #2 |
Re: Kwik-Lift
08-01-2021, 04:31 PM | #3 |
Re: Kwik-Lift
katy Thank You! I do have that but wanted to talk to someone that already has on and get their prospective for Pros & Cons! Again, thanks for responding!
08-02-2021, 10:30 AM | #4 |
Re: Kwik-Lift
I posted the link because I didn't know what a "Kwik-Lift" is and had to look it up. I assumed that probably others on here were also unfamiliar w/them.
08-02-2021, 12:48 PM | #5 |
Re: Kwik-Lift
katyThanks again! Sorry about that I didn't post the link. Apparently no one else in the Model A community knows what they are either as there has been 308 views and YOU are the only one who responded!
Thanks Again katy! |
08-02-2021, 01:36 PM | #6 | |
Re: Kwik-Lift
In the case of using with a Model-A, access to the axles is very easy and installing jack stands to hold your vehicle in the air is easy too. With that Kwik-Lift stand, it severely limits your ability to crawl under your Model-A, ...which is the reason most people would want one. My recommendation is spend the money for a real drive-on lift instead of this. |
08-02-2021, 08:07 PM | #7 |
Re: Kwik-Lift
Brent,
I have to respectfully disagree with about "it severely limits your ability to crawl under your Model-A". Well this stand gets the car tires off the floor by 20" and of course the Frame is up approx. 22" from the bottom of the tires. My figuring tells me that's 42" that the Frame is off the floor. ALSO the Video shows a gentleman on a creeper going UNDER the ramp to get to the middle of the car. As to cost drive on ones are at least twice the cost! In my case I only have 10 1/2 foot ceilings so with the Fordor I won't be able to go under it standing up. Thanks for responding to my Post! Joe |
