Old 09-08-2019, 09:44 PM   #1
boondocksdrew
Default L-4 Kingston carburetor seat
I had a tough time removing this seat and probably should run a tap in there to clean up the threads.
I thought there would be a new seat in the rebuild kit I have but it ended up needing to be ordered separately so I don't have it yet. Anybody happen to know the diameter and thread spacing on this?
boondocksdrew is offline   Reply With Quote
Old 09-09-2019, 02:34 AM   #2
tiger.1000
Default Re: L-4 Kingston carburetor seat
Have you tried Ecklers ? They seem to have a varied selection of Model T parts
Tel 877-815-5799
tiger.1000 is offline   Reply With Quote
Old 09-09-2019, 11:09 PM   #3
redmodelt
redmodelt's Avatar
Where are you located?. When you get one, get the original style not the two ball type.
Old 09-10-2019, 08:14 AM   #4
Royce P
Royce P's Avatar
https://www.modeltford.com/item/6172.aspx
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
Old 09-11-2019, 08:20 PM   #5
boondocksdrew
I had the replacement ordered already, it looks like the one pictured and identical to the mangled one that came out, so it should be original. I wonder if the "two ball" type was the part in the kit I didn't recognize.
The problem is just that the threads in the carburetor were slightly damaged, so I need to run a tap or at least a hard bolt of the right size in there to clean it up so I don't damage the threads on the new seat.
The new part arrived so I'll just take the seat into Lowes and use the bolt sizer to figure out what I need.
Does that copper washer go under the bottom of the seat? Don't recall that coming out with the old one, I'll have to look again.
Old 09-13-2019, 09:00 AM   #6
Royce P
Royce P's Avatar
I have not figured out why the copper washer is there. I toss them in the trash.
1910 Touring
1914 Touring
1915 Touring
Old 10-02-2019, 09:51 PM   #7
boondocksdrew
For future reference, a 3/8 - 16 tap worked to repair the seat threads.
Since the carb had a lot of pitting and surface rust, after it came out of the dip bucket I hit it with a wire dremel brush. Then after taping off the openings, I coated it with POR15 fuel tank sealer. I've had good results with regular POR15 so we'll see how this works out.
