Old 11-13-2020, 04:33 PM   #1
Mike..Yorba Linda
Default Y block water temp sending unit
How do you check to verify it works? It's 12 volt. Thanks.....
Mike..Yorba Linda is offline   Reply With Quote
Old 11-13-2020, 10:30 PM   #2
fordor41
fordor41's Avatar
Default Re: Y block water temp sending unit
If your temp gauge doesn't work at all it could be gauge or sender. ground sender wire to a ground, with ign. on and gauge should move to hot. if so I'd suspect bad sender. If gauge doesn't read grounded, I'd suspect bad gauge or wiring. To check the sender, rig a long wire from the sender connection to the sender wire, ground the case of the sender and with the ign on heat the sender with a flame. If gauge tested Ok and the heated sender doesn't change the gauge bad sender or wiring
fordor41 is offline   Reply With Quote
Old 11-13-2020, 11:04 PM   #3
Mike..Yorba Linda
I’ll give it a try....Thanks...
