Old 08-18-2020, 01:19 AM   #1
Tim Warren
Default mounting vase bracket on 31 SW Town Sedan
Can someone tell me if there is a wood in the door post behind the driver's seat. I don't seem to get much of a bite when trying to mount the vase bracket. Thank you in advance.
Tim Warren is offline   Reply With Quote
Old 08-18-2020, 06:53 AM   #2
jack wingard
Default Re: mounting vase bracket on 31 SW Town Sedan
My 29 Briggs Fordor, yes
jack wingard is offline   Reply With Quote
Old 08-18-2020, 09:44 AM   #3
1930artdeco
1930artdeco's Avatar
Not in a slant window. It should be all steel.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 08-18-2020, 05:23 PM   #4
Jerry in Shasta
Jerry in Shasta's Avatar
The "B" pillar has a wood tack strip. I;m mounting mine on the tack strip just behind the rear quarter window
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 08-19-2020, 05:44 PM   #5
duke36
The A pillar let's call the front windshield location. The B pillar (with the light switch deluxe location) has edge uphol tacking wood strips. The C pillar has a wood vertical strip and small metal plate at the top with 2 horiz tapped holes to receive the pull bracket. If at the C pillar, need to be below that plate. Probe with an upholstery needle. Or further to the rear adjacent to the quarter window is where many install the brackets.
Old 08-19-2020, 09:35 PM   #6
Brian SATX
Brian SATX's Avatar
Here si a link that shows all the wood in the different Fordors. http://fordwood.com/fordors.htm
Brian SATX
Brian SATX is offline   Reply With Quote
