12-25-2013, 02:03 PM | #1 |
Rear Hub scare
Decided today was a good day to go through the rear end on the A.
Started with banjo and, although the fluid was very low and twice as thick as 600W should be, all gears were intact and surfaces showing virtually no wear. Flushed it out and put in fresh lube. And that, as they say, was the good news part of the day. Then I pulled the wheels off.... grease e v e r y w h e r e..... The entire back of the drivers side wheel was coated as was the castle nut. Pax side had a little but about what I would expect. Pulled the cotter pin and was able to.... (ready for this?) remove the nut AND the hub without tools...... both sides. Boy, I'm thinking trouble ahead...... Drivers side hub had no fiber washer to seal the end. Drivers side had a rubber hose washer. (I've seen that used on other cars so I have no issue with it as long as a quality one is used. This one was not) First glance had me still worried about damage....but I seem to have received a Christmas present from the high priests of all things mechanical. Disassembled inspection shows no damage ... anywhere! Everything cleaned, lubed and reassembled although I am going to replace the seals and have to decide whether to use silicone seals or order some fiber seals and install them Last edited by MrWzrd; 12-25-2013 at 02:18 PM. |
12-25-2013, 02:28 PM | #2 |
Re: Rear Hub scare
You probably have to remove the entire Rear End and Spring. To Look over everything and Replace the inner Axle Seals, as some one put Mud (Heavy Lube) in the Center Housing so as oil would not run out! Not a fun Job, but a Necessary one it sounds like to Me with your Situation. Better change the Drive shaft Seal also while you have it apart.
Differential Repair Ins http://www.ocmafc.org/Tom%20Endy%27s...20Articles.htm . http://www.snydersantiqueauto.com/672 Last edited by Jazzjr; 12-25-2013 at 02:36 PM. |
12-25-2013, 08:56 PM | #3 |
Re: Rear Hub scare
Perhaps the rear wheel bearing fitting was greased so much that it greased up the oil and the brakes
12-25-2013, 10:13 PM | #4 | |
Re: Rear Hub scare
The inner axle seals are not leaking at all and unless they start to I'm not pulling the rear end apart. The grease all over the backside of the wheel was from the missing fiber seal at the very end of the axle. The seal that sits in the groove under the washer and castle nut. |
12-26-2013, 12:27 AM | #5 |
Re: Rear Hub scare
