Old 12-21-2013, 04:09 PM   #1
woodrow
Default Won't start?
About 30 days ago we bought our first Model A---a 1931 Model A Town Sedan. Every time I tried to start the car it always fired right up, however today is warmer and VERY humid. I tried 2 or 3 different times today to start the car but nothing happened except flooding after a minute or so. Never bumped at all. The 1915 Model T started right up with the crank on Magneto and they sit side by side. I'd appreciate any suggestions because in a few days the car will be used to drive a granddaughter away from her wedding. Thanks,
woodrow is offline   Reply With Quote
Old 12-21-2013, 05:54 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Won't start?
Sounds as if you may have flooded it.
Does it have spark ?
Old 12-21-2013, 05:58 PM   #3
MrWzrd
"never bumped at all'....would have me looking at no spark. Ignition switch, ground, points, timing, etc.
No spark will usually lead to "flooding" in the attempt to get it started.
Since you have a T you are probably well familiar with the feel and sound of compression.... so with the ignition off pull the engine through by hand to do a quick check that the mechanical insides feel and sound right. If they do...go chase down the electrical. (ignition)
MrWzrd is offline   Reply With Quote
Old 12-21-2013, 06:01 PM   #4
SkipShift
SkipShift's Avatar
I'm a new 31 SW TS owner too. When mine wouldn't start I discovered a blown fuse on top of the starter caused by my shorting out one of the lights.
SkipShift is offline   Reply With Quote
Old 12-21-2013, 06:56 PM   #5
woodrow
Well, good grief. I guess I just flooded the car when I tried to start it earlier in the day. It was very warm outside and VERY humid---don't know if that's a factor or not. Anyway, it's cooler now and the humidity has gone down a bunch and the car started right off. After reading your kind and patient posts I first checked the fuse going in to the starter and it's fine. As I mentioned in my first post, we have only had the car for about 30 days, it's our first Model A and I guess I'll have to learn it's quirks. Thanks for your help. I appreciate it very much.
Old 12-22-2013, 08:18 AM   #6
insomniacshotrods
insomniacshotrods's Avatar
Glad you got it started.
Enjoy life , it has an expiration date.
insomniacshotrods is offline   Reply With Quote
Old 12-22-2013, 08:54 AM   #7
jkcrosson
jkcrosson's Avatar
My car does not like damp humid weather. We have been going through weeks of Seattle type wet weather. Mine cranked fine on Friday night and pitched a fit cranking Saturday morning. Only difference was Saturday morning was 15 degrees warmer and misty rain. My car is parked on a carport that the concrete sweats terrible.
Jamie Crosson
1929 Tudor
Looking for an Original 888 Key
jkcrosson is offline   Reply With Quote
Old 12-22-2013, 08:54 AM   #8
Steve Wastler
Steve Wastler's Avatar
Since it seems you have determined it is exasperated by humidity, it would be wise to thuroughly inspect your electrical system and clean each and every connection, points, rotor cap, etc....
Steve Wastler is offline   Reply With Quote
Old 12-22-2013, 09:13 AM   #9
jkcrosson
jkcrosson's Avatar
I've got good spark at the points. That was the first thing I checked.
Jamie Crosson
1929 Tudor
Old 12-22-2013, 04:10 PM   #10
Ed H.
Condensation on cap and wires will short out the system. Even tho you have spark at the points.
Try spraying with WD-40, that will usually get you going if the issue is condensation.
If you see a bomb technician running, do everything in your power to keep up with him.
United States Navy
Ed H. is offline   Reply With Quote
Old 12-22-2013, 04:17 PM   #11
Mike V. Florida
Mike V. Florida's Avatar
Not just check but as Steve says clean the connections. Sure sounds like pitted points to me.
Old 12-22-2013, 04:27 PM   #12
Mitch//pa
you can find your moisture problem by duplicating it with a spray bottle of water. mist individual components //areas until the problem reoccurs.
Old 12-23-2013, 02:56 AM   #13
Barber31
Barber31's Avatar
One thing I like to do is ruff up all electrical contact points and apply a smidge of bulb grease or dialectric grease. Usually on the spark plug terminals, distributor and rotor contacts, terminal box contacts and coil wire contact ends. I feel it helps with them not getting dirt/rust or condensation in the nook and crannies.
Barber31 is offline   Reply With Quote
