Old 09-17-2018, 05:46 PM   #1
daren007
Default Model A engine cam bearing dimension
Can someone give me the model A engine block cam bearing dimension.
Cavity bore diameter. Thanks. Daren
daren007 is offline   Reply With Quote
Old 09-17-2018, 10:31 PM   #2
jetmek
Default Re: Model A engine cam bearing dimension
going from memory here but 1.560 sounds right
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 09-17-2018, 11:01 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
I have max clearance .003 from service bulletins
new cam diameter of 1.560 ---from bill stipe site
a low mileage block that I took apart that still has machining marks has .0015 clearance with original cam that shows no wear
a center cam bearing with .005 clearance has the same "open" cross section as the oil feed to the valve chamber ----
