05-31-2021, 12:01 AM | #1 |
37-39 Water Pumps
Could someone please tell me how much end float the pulley/impellor shaft should have on a correctly assembled, good condition, original 37-39 water pump? (Half inch diameter pulley/impellor shaft with the bronze bush)
Is 3mm end float good or bad? Last edited by FlatheadEric; 05-31-2021 at 01:14 AM. |
05-31-2021, 05:18 PM | #2 |
Re: 37-39 Water Pumps
The pulley moves forward about 3/16" when engine RPM's are increased on
pumps with spring loaded seals. With engine off you should be able to move the pulley forward towards the radiator 3/16" it should spring back every time you release it. There are also pumps that the bearing is made on the shaft that stay in a fixed position and that pulley don't move forward. I prefer the ones that move. G.M.
www.fordcollector.com |
06-01-2021, 12:47 AM | #3 |
Thanks G.M.
That is what both pumps do. I can move them both forward 3-4mm (3/16") and they return when I release them. I just received these pumps and on installing them I found that the left hand pump is dripping water so it looks like a new seal is required. |
06-01-2021, 01:36 AM | #4 | |
Overseas with shipping not viable. Phil NZ |
06-01-2021, 06:48 AM | #5 |
If the leaking one pulls forward and springs back, it might be ok after putting a few miles on it.
Mart. |
06-01-2021, 09:56 AM | #6 | |
running at a fast idle take a small piece of wood and move the pulley forward and push it back against the seal. G.M.
06-01-2021, 10:02 AM | #7 | |
is not getting squeezed tight and the leak looks like the seal is leaking. If I recall the bolts are 7/8" long. G.M.
