01-17-2018, 02:27 PM | #1 |
Difference in compression ratio on cast iron heads?
I had read that the cast iron heads on a 34 truck had a higher compression ratio than the aluminum heads used on cars. Is this true or just more disinformation on the internet?
Matt 24:36-41 |
01-17-2018, 02:43 PM | #2 |
Re: Difference in compression ratio on cast iron heads?
If i remember right the chamber volume of the cast iron heads are bigger...
I might be wrong but i think it´s 60 for aluminum and 80 for the cast iron heads. |
01-17-2018, 05:17 PM | #3 |
Thanks
Matt 24:36-41 |
01-17-2018, 06:32 PM | #4 |
Look in the green bible parts book,or the service bulletins,In mine it shows a list of the head part numbers cast iron or alloy and the chamber volume also the comp ratio.
Lawrie |
01-17-2018, 06:49 PM | #5 |
There is a compression ratio chart over on the HAMB that covers just about every head made by Ford plus a bunch of aftermarket ones and all the different stroke combinations. It's about 5 pages worth and took a lot of research to put it all together. This is a link to where it can be down loaded. https://www.jalopyjournal.com/forum/...hoices.482189/
01-17-2018, 07:42 PM | #6 |
01-18-2018, 10:44 AM | #7 |
Thanks for the info
Matt 24:36-41 |
01-18-2018, 11:12 AM | #8 |
Believe these are the Green Book values.
01-18-2018, 06:51 PM | #9 |
Damn I knew my [21 stud] heads were good ; ) 7.5:1
01-18-2018, 10:58 PM | #10 |
The pistons must have been different for the aluminum and iron head engines because even with that huge difference in volume, the c.r. is the same.
01-18-2018, 11:09 PM | #11 |
The chart represents the factory specs. However, they're all over the place, so measure them.
01-19-2018, 09:00 AM | #12 |
I had heard that the aluminum "Denver" heads had the most compression because of the high elevation. Here's a chart I found in the internet years ago.
