01-17-2018, 08:49 PM | #21 |
Re: Calling all Side Mount 31 Carbs that you have
I am going to have to really watch the swap meets.
01-17-2018, 08:55 PM | #22 | |
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
01-17-2018, 09:14 PM | #23 |
Looks like some of my Zenith 3 carbs going on EBay soon
01-18-2018, 11:00 AM | #24 |
Thanks Joop for the good pictures . I wonder if Simmons ever made an alloy side bowl version . The alloy Simmons carbs were made for fuel economy . I've got a couple of the regular Simmons alloy carbs but have never seen a side bowl version . I'll bet that they made one .
01-18-2018, 11:11 AM | #25 |
I will vouch for the seller. He is an honest upstanding Model A guy
TerryO |
01-18-2018, 03:41 PM | #26 | |
01-18-2018, 06:07 PM | #27 |
Thanks F.M. I've been running a regular cast iron Simmons carburetor on one of my model A's going on 12 years and I haven't had to do anything to it. It doesn't leak a drop yet. I know that its hard to believe ! All of the different updraft carbs that I have ever used, sooner or later leaked. Simmons cast iron carbs were far better that Zenith in my opinion. I've never tried the alloy Simmons .
Last edited by Purdy Swoft; 01-18-2018 at 06:14 PM. Reason: corrected a typing error. |
01-18-2018, 06:51 PM | #28 |
Mr. Purdy,
I've got a June, 1933, Simmons catalog. Replacement carburetors, Part number: A-9510-B 1928-31, A-9510-C Late 1931, B-9510 4-cyl. 1932. All carbs look like they are cast iron. The alloy carbs must have come out later. Bob-A |
01-18-2018, 08:31 PM | #29 |
Bob , I really don't know when they came out but you are probably right . The first Simmons carb that I got was a rough Simmons alloy . I only paid 5 dollars for it . I patched it up with whatever Zenith parts that could be fitted to it. I never got around to using it . I kept it because I figured it was sorta rare .There was some articles about different carburetors in the restorer in 94-95 and the Simmons alloy was one that was briefly mentioned . Later in 03 , I think , There was an article in the Fast magazine about how much air some of the different updraft carburetors flowed .The model B zenith was best . TheTillotson model X was said to flow second best . TheMarvel and then the Zenith one and two was the next best . The Simmons alloy was way worse than any of the others . The tests were done by an engineer with a vacume cleaner . The Cast iron Simmons wasn't tested . The Simmons alloy has a much smaller venturi and jets than the cast iron perfoprmance Simmons carb . I was allways more concerned with more power than better fuel economy . I only keep the alloy carbs because they are part of my Simmons carburetor collection . I haven't found a lot of info . The cast iron Simmons is by far my favorite up draft carburetor . Maybe someone can tell us more about the history of these carbs .
Purdy . Last edited by Purdy Swoft; 01-18-2018 at 08:36 PM. |
01-18-2018, 09:19 PM | #30 |
Hi, this is my Carburetor on eBay, I can assure you I don’t have my “buddies” bidding it up, I will also agree it is a little insane how much it’s going for, but it’s out of my control
01-18-2018, 09:22 PM | #31 |
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
01-18-2018, 11:29 PM | #32 |
It's the fact that it is a "3" that makes it so rare.
01-19-2018, 08:27 AM | #33 |
Alloy "SIMMONS" Last picture is the illustrious alloy side bowl (only 1 produced) ;-))) ... Last edited by Joop; 01-19-2018 at 08:59 AM. |
01-23-2018, 11:49 AM | #34 |
It doesn't have to be a Zenith 3 to be a side bowl carb . Without going out and looking I think that mine is a Zenith 1 . The first time that I ever remember mention of the Zenith 3 was when Rex Reheis found a few of them in the 90s .There was a write up in one of the national model A club mags . I think that Rex was asking around five hundred dollars for one of them. This was nearly 20 years ago and I don't think that any of them were side bowl . Zenith 3 carbs Bring huge prices because of their rarity to the right collector . I've read that the Zenith 3 was made by Ford as a replacement . I've got to wonder if the Zenith 3 came on any of the model A's or was only available as a replacement . Ford could probably make these thin delicate carbs for less than he could buy carbs from Zenith or Holley .
01-23-2018, 11:49 PM | #35 |
They were early to end 1931 production carbs. I think the first replacements were the 1932 production carbs.
