01-18-2018, 04:54 PM | #1 |
Condenser value
I have 3 new condensers used for distributors. I measured them with my capacitor meter. One was .227 uf, one was .231 uf and one was .262 uf. What is the correct range for model A condensers?
Rusty Nelson |
01-18-2018, 05:58 PM | #2 |
Re: Condenser value
Rusty,
Do a site search of 'Condensers' and a response from Tom Eddy. "Normal is .287 micro farads" ..... Tom Eddy JB |
01-18-2018, 06:08 PM | #3 |
Re: Condenser value
Is there a tolerance? Perhaps those readings were just due to manufacturing differences.
01-18-2018, 10:45 PM | #4 |
Re: Condenser value
Dog here,
We thought you were SELLIN' Condensors---LOL Buster T.
01-18-2018, 10:54 PM | #5 | |
Re: Condenser value
https://www.fordbarn.com/forum/showt...ondenser+value
All steel from pedal to wheel |
01-18-2018, 11:10 PM | #6 |
Re: Condenser value
The most common tolerance variation for capacitors is 5% or 10% but some plastic capacitors are rated as low as ±1%.
01-18-2018, 11:16 PM | #7 |
Re: Condenser value
The condenser value is not terribly critical. Somewhere around a quarter of a microFarad is reasonable, which is what you are measuring. I would say (gut feel) that anything between .2 and .3 is good. The condenser and the coil work together and there are also variances in the inductive value of the coil, so you would have to get real scientific to determine what the optimum value would be of either part.
01-19-2018, 12:25 AM | #8 |
Re: Condenser value
01-19-2018, 07:06 AM | #9 |
Re: Condenser value
Plus how accurate is the meter making the measurement? With the types of leads and such the meters are generally not the most accurate also.
01-19-2018, 10:47 AM | #10 |
Re: Condenser value
My test: I'd charge one with the 110 Volt growler test light probes. Later, if you jumped it & it sparked, it was GOOD.---Is this a GOOD test????
Bill W.
01-19-2018, 10:56 AM | #11 |
Re: Condenser value
I got a better one (like we did in school with the first years electronics) ; you charge one (in our case 220V) and hand it over to someone.... You will immediatly know if the condensor is a good one ... If this person screems the condensor is good.
01-19-2018, 11:07 AM | #12 |
Re: Condenser value
Yep. Done that. Very conclusive test.
