10-16-2020, 08:58 PM | #1 |
Battery Tenders
For years I have used a Battery Tender to keep my Optimas fully charged. Worked well for years. This was a box about 4x5x6, or close. Well, I think it finally bit the dust, at least the battery did. I replaced the battery but the old Battery Tender seems to have been discontinued, or at least I cannot find one at Wally World. I bought an EverStart 6-12 V Battery Charger & Maintainer 3A Charge rate. but have yet to hook it up. (The Battery tender was 1.25 Amps.) This battery charger/maintainer is not a box looking thing but looks something like a 1 lb link of sausage that has been stepped on and flattened lengthwise if you can envision that. Got it at Wally World for some $23.00, about like the old Battery Tenders. They have served me well over the years. Anyone have any experience with these? or know where I might purchase a new Battery Tender? Thanks guys.
Life is like a roll of toilet paper. The closer to the end, the faster it goes. It is better to be seen, than viewed. "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". Last edited by Lawson Cox; 10-16-2020 at 09:13 PM. |
10-16-2020, 10:00 PM | #2 |
Re: Battery Tenders
Lawson, make sure you dont start your engine with that charger still connected to the battery. That charger is probably made in China. For $23.00 it is most likely crap. You only get what you pay for. Regards, Kevin.
10-16-2020, 10:06 PM | #3 |
Re: Battery Tenders
Lawson, I am using a C-Tec battery tender. It's a wonderful unit that does a great job. Been using it continually for last 6 years. Small and compact.
Here's the website. Pick one that works for you. https://smartercharger.com/ |
10-16-2020, 10:49 PM | #4 |
Re: Battery Tenders
Battery Tender 021-0144 Battery Tender Plus 6V Battery Charger
https://www.chevsofthe40s.com/detail...er_6_Volt.html
10-16-2020, 11:06 PM | #5 | |
Re: Battery Tenders
10-17-2020, 01:57 AM | #6 |
Re: Battery Tenders
10-17-2020, 02:55 AM | #7 |
Re: Battery Tenders
personaly i wound up with a cheap solar panel charger [gift] but i tell you what its an been absolute gem works spot on and bonus costs nothing to run
10-17-2020, 07:39 AM | #8 |
Re: Battery Tenders
I use a NOCO, expensive, but it has a 6v AGM setting
No job’s done ‘til it’s all done |
10-17-2020, 02:24 PM | #9 | |
Re: Battery Tenders
I also have a Battery Tender, and a Battery MINder Plus, and both of these units seem to be a little more 'friendly' to me. I have all three of these units currently running. On one car, the CTEK will not work at all, where as the other two units seem to work ok. The CTEK is probably the best of the three units, if I can believe their published info. I just wish I could understand what it's doing, and when. |
10-17-2020, 04:18 PM | #10 |
Re: Battery Tenders
I got a battery desalphator, I connected it to a battery that wouldn’t even crank the flat head when fully charged, after about a month is was as good as new,
10-17-2020, 07:49 PM | #11 |
Re: Battery Tenders
I use NOCO Genuis chargers they are great
10-17-2020, 07:53 PM | #12 |
Re: Battery Tenders
I put a Wally world battery tender on our 38 conv'
, had a new Ford script battery on it; didn't check on it; when I did the battery was hot and boiled dry; put new acid in it, it never charged up, the company send the tender back with $10.00 and they would repair it, I said no thanks; they wouldn't replace my battery |
10-17-2020, 08:32 PM | #13 |
Re: Battery Tenders
Do I look like I have a plan B? |
10-17-2020, 08:49 PM | #14 | |
Re: Battery Tenders
10-17-2020, 09:40 PM | #15 |
Re: Battery Tenders
I have battery tenders on my cars when I go to Florida for 6 months every winter. I was concerned about overcharging, so I bought a simple timer from K-Mart. After a few months of experimentation, I found that if you set the timer to power up the maintainers for 15 minutes a day, it will keep the batteries up without worrying about overcharging and boiling. It cost me $6.99.
10-18-2020, 02:15 AM | #16 |
Re: Battery Tenders
Tubman, that is a great idea. I may try it myself.
10-18-2020, 06:18 PM | #17 |
Re: Battery Tenders
Schumaker is the brand that cooked my battery
10-21-2020, 08:06 PM | #18 |
Re: Battery Tenders
We own 4 "collector" cars, we use; 2ea C-tek 4.3us, a Deltran, & a Schauer Charge Master CM6A for our odyssey battery and they are all somewhat different but kinda do the same thing, C-tek and the Schauer are the more advanced models w/newer features where as my Deltran (same size as the 6v one shown above) is a tank workhorse but w/less features. Really comes down to how much you want to spend on one and sorry to say, all of them are made in china, afaik! YMMV
Regards, Todd 1936 FORD Tudor Slantback "cajunhotrodder" on instagram/youtube |
10-21-2020, 08:20 PM | #19 |
Re: Battery Tenders
Friends car was burned badly by a tender that went bad. Luckily a circuit breaker did its job before his shop caught on fire too, I need educated here-why does a person need a tender? I have seven batts and they have all been fine in the spring after a 4 or 5 month siesta.
10-21-2020, 08:35 PM | #20 | |
Re: Battery Tenders
My optima is on a c-tek, its 12 yrs old (battery)!!, I drive that car once or twice a year, literally. I use them on power equipment and 5 out of the 7 cars we own that are not daily drivers, YMMV. My 2008 f150 is the worst at parasitic battery drain, its on one too. I drive it about 1 week out of the month.
