Old 10-10-2020, 09:22 PM   #1
hombres ruin
hombres ruin's Avatar
Default How much play (movement) should there be in a gen pulley?
Hey guys. Question. How much play or movement should be in a 6V generator pulley. I have had it re built but when the car is going I hear it make a audible clunk noise . I turned the engine off and I can rock the pulley back and forth not too sloppy but enough to replicate the sound I am hearing . Is this normal ?
"I have built my organisation on fear"..Al Capone.
hombres ruin is offline   Reply With Quote
Old 10-10-2020, 10:05 PM   #2
DavidG
DavidG's Avatar
Default Re: How much play (movement) should there be in a gen pulley?
There should be no end play of a generator armature (and therefore no fan end play). Perhaps the pulley is loose on the end of the armature.
Old 10-11-2020, 08:20 AM   #3
hombres ruin
Thanks David . I have had this gen rebuilt twice and the movement in the pulley keeps coming back. I have followed the 41 ford Manual for correct belt tension and it still works loose. I will pull it and replace it I guess .
Old 10-11-2020, 08:25 AM   #4
Kube
Kube's Avatar
Can you post a photo of the generator?
Some pulleys required a clip at the end of the armature shaft. That clip is very oft times absent.
There's really no "good" reason this continues to happen and is most likely as easy fix.
