Old 10-10-2020, 08:17 AM   #1
Jacques1960
Jacques1960's Avatar
Default 1938 Woodie - closing gap in wood frame
The wooden frame and panel insert gaps are all tight, with the notable exception of the right rear middle horizontal frame member, which has a 1/4” gap relative to the tailgate frame. Before I begin any disassembly, is there an internal means of closing this gap mechanically (tightening a screw or bolt) or is a longer, replacement wood member called for ? Photos to follow .Thank you.
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 10-10-2020, 10:39 AM   #2
Kube
Kube's Avatar
Default Re: 1938 Woodie - closing gap in wood frame
My guess, and only a guess, is one or more pieces never fit very well together. There's no "adjustment" back there.
Without having that panel in my hands, I can't say for certain whether or not it could be disassembled and reassembled "tighter".
Old 10-10-2020, 10:41 AM   #3
GB SISSON
GB SISSON's Avatar
I would think it's best to draw the parts back together. Is this a concourse restoration? There are some pretty neat hidden mechanical fasteners such as 'tite-joint connectors' that may be able to be hidden under the surface on the inside with some creative router work. Once you start making longer horizontals, I'm afraid alignment problems will soon follow. Can you post a picture inside and outside of the problem joint?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 10-10-2020, 10:58 AM   #4
Jacques1960
Was able to add photos via album !
Old 10-10-2020, 12:02 PM   #5
wga
wga's Avatar
That photo of the horizontal piece fitting in the vertical, is a mortise and tenon joint. They become loose over time. Could be that joint has hidden rot, and a new tenon
and or mortise. Belong to the National Woodie Club? There are resources there. Also there is a woodies group on Yahoo.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 10-10-2020, 12:13 PM   #6
Jacques1960
Thank you
Old 10-10-2020, 12:42 PM   #7
JSeery
JSeery's Avatar
To get the photos in the thread.
Old 10-11-2020, 08:39 AM   #8
Bill
Bill's Avatar
Hey Jaques, welcome to Woodie World! Just for fun go back to the archives of Bring A Trailer. There are five examples of 38 Ford wagons with literally 100s of pictures detailing the wood fitment. You will note there are lotsa wide gaps in certain areas. Ironic your car is featured there minus a clear pic of the problem area... Over 82 years the wood suffers if the car has been exposed to the elements. Over time pieces get replaced/refitted as required. The particular gap in question here appears to be extra open in my opinion. Be careful if you decide to start taking it apart. Could be a can of worms....Nothing wrong with lotsa patina on a woodie. Good luck and certainly join the National woodie Club as there are several members in Maine who would be eager to offer advice/help as required.Maine was a hotbed for woodies back in the day. Mine came from Wiscasset 40 years ago!Bill
Bill is offline   Reply With Quote
