Old 10-09-2020, 07:50 PM   #1
Steve in Denver
Steve in Denver's Avatar
Default '36 spare tire cover seal won't fit
Before I got my 5W painted, I dug out the old, nearly gone, spare tire seal. I bought a new one from Mac. I am trying to install it. One way it is too fat/thick to fit, the other way it is way too thin, unless I damage the metal cover and crimp it with pliers, which I would prefer not to do. Or I could glue it in, but which way is correct?
Steve in Denver is offline   Reply With Quote
Old 10-09-2020, 08:21 PM   #2
woodiewagon46
Default Re: '36 spare tire cover seal won't fit
Before you damage the steel cover I would try to order one from another supplier. It might be a better fit. I purchased my rubber for the spare tire cover for my '46 Woodie from Dennis Carpenter and it fit perfectly.
woodiewagon46 is offline   Reply With Quote
Old 10-09-2020, 08:25 PM   #3
Gary Tosel
Gary Tosel's Avatar
The thin side goes into the groove on the spare tire cover. Is that foam rubber or solid rubber? I have used the seal from Drake (solid rubber) for two installations and they it fit fine without crimping the cover. It should stay in place without glue. It would appear that if you use this seal, you would need to glue in place.
Gary Tosel is offline   Reply With Quote
Old 10-09-2020, 09:32 PM   #4
Steve in Denver
The thin side is way too thin, it would take something twice as thick, and both sides are very solid rubber, I would need vice grips to crush the thick part enough to get it in.
Monday I will check with some of the other suppliers.
I do appreciate input from others.
Old 10-09-2020, 10:54 PM   #5
Brian
Brian's Avatar
I too can recommend the Drake product. it'll fit properly.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 10-10-2020, 09:27 AM   #6
Steve in Denver
Thanks, I'll order one on Monday, but with "Out-Of-Stock Bob" it might be tough getting one from him. I asked him something about windshield wipers once, and all he said was that he gets lots of his stuff from the other suppliers. If they are out, so is he.
Old 10-10-2020, 09:30 AM   #7
Kube
Kube's Avatar
I'd installed a Carpenter seal a few months ago. It was rubber - not foam, and fit wonderfully.
Old 10-10-2020, 01:19 PM   #8
Steve in Denver
I was able to get it in. I inserted the larger round edge into the grove. I put the small flap towards the center of the cover. I used lots of vaseline and a wide screwdriver and pushed it. It took about an hour and a half but I didn't scratch anything.
I started installing it dead center at the bottom. I should have left myself about 8 or 10 inches as it seemed to scoot as I went around it and now instead of being right at the bottom, it is 8 inches to the right. There was about 2 feet of extra gasket and I did leave myself some extra just in case what I installed shrinks.
Now on to reassembling the rest of the car after the paint job.
Thanks everyone for your input.
Old 10-10-2020, 03:02 PM   #9
Don Rogers
Don Rogers's Avatar
Here's a closeup from an engineering drawing showing the seal (anti-rattler) in place
Don Rogers is offline   Reply With Quote
Old 10-10-2020, 07:37 PM   #10
Steve in Denver
Thanks, that really helps.
