Old 10-04-2020, 11:30 AM   #1
StianK
Default Oil gallery plug to 8ba
Hi. Iím building a 8ba , and need new oil gallery plugs. I live in Norway and donít have many shops to by inch treads bolts and flathead parts at all. Any one knows where to by Iíll be glad.
Regarding Stian
StianK is offline   Reply With Quote
Old 10-04-2020, 11:45 AM   #2
George
George's Avatar
Default Re: Oil gallery plug to 8ba
Is this what you need?
https://thirdgenauto.com/product/193...ouldered-plug/
George is offline   Reply With Quote
Old 10-04-2020, 12:15 PM   #3
flatjack9
flatjack9's Avatar
No, that is for the earlier engine, but 3rd Gen will have the right one.
Old 10-04-2020, 02:52 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
The stock plug has a screw driver slot but one can be made by using an allen pipe plug, making sure to remove material from it to prevent it from hitting the timing gear
Old 10-04-2020, 06:15 PM   #5
cadillac512
cadillac512's Avatar
Quote;
" I live in Norway and don’t have many shops to by inch treads bolts"
Availability in Norway is the problem. Our inch based hardware isn't so common there. Having said that, a 3/8-19 BSP tapered plug may fit if the threads in the block are chased with the proper tap. Yes, some thread damage will result, but I'll bet it would be fine.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
cadillac512 is offline   Reply With Quote
Old 10-04-2020, 07:20 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by cadillac512 View Post
Quote;
Norway does have access to EBAY as well as other suppliers.
Might not be available at the corner hardware store but a search online will yield results.
Old 10-04-2020, 07:32 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
Quote;
You sure you really want to risk deforming the original threads, IF it doesn't seal properly? Thread SHAPES and ANGLES are different, at the least. DD
NPT:
BSP:
DIFFERENCES Chart:
T5 W/TORQUE TUBE
It's interesting that so many people know SO MUCH stuff....that just ain't so!
Old 10-04-2020, 07:48 PM   #8
Pete
Pete's Avatar
The amount of leakage from the different thread pitches will be insignificant.
It is standard practice to drill a .040 (1mm) hole in the plug on high performance engines.
(to oil the gear)
Old 10-04-2020, 07:54 PM   #9
34PKUP
34PKUP's Avatar
Originally Posted by StianK View Post
Hi. I’m building a 8ba , and need new oil gallery plugs. I live in Norway and don’t have many shops to by inch treads bolts and flathead parts at all. Any one knows where to by I’ll be glad.
Regarding Stian
Try hardware and plumbing supply outlets as well as EBAY as stated.
By all means do NOT do any odd size re-tapping.
The plugs are available.
34PKUP is offline   Reply With Quote
Old 10-06-2020, 06:07 AM   #10
StianK
Thanks for answer . So treads are 3/8-19 thanks .
Old 10-06-2020, 06:54 AM   #11
51 MERC-CT
51 MERC-CT's Avatar
WRONG--- The the threads are (NPT 3/8-18)
Thread Tools
Display Modes
