08-30-2020, 02:34 PM | #1 |
93 octane fuel
Will 93 octane fuel make my engine chugg
08-30-2020, 03:00 PM | #2 |
Re: 93 octane fuel
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
08-30-2020, 05:13 PM | #3 |
Re: 93 octane fuel
Shouldn't need that high an octane fuel unless you are running a high compression ratio. But to high an octane shouldn't cause a driving issue. How about bad fuel? I have seen several cases where the fuel (at the supple station) is contaminated with something, like diesel or water, etc.
08-30-2020, 05:32 PM | #4 |
Re: 93 octane fuel
The chugg description will need further clarification. At what rpm is this chug and is it when the engine is under load or no? Engines will miss and rpm fluctuations can happen under certain conditions but the only thing that chugs is a steam engine in my way of thinking. Stuck valves can cause after fire in the exhaust and a lean fuel mixture can cause backfire through the carburetor. These would be like the definition of "chug" when related to motor vehicles.
08-30-2020, 05:36 PM | #5 |
Re: 93 octane fuel
The question, as asked, cannot be answered. Please define what "chugg" means? Running octane much higher than the requirements of the engine can cause some performance issues but I would not refer to that as being a "chugg".
08-30-2020, 05:55 PM | #6 |
Re: 93 octane fuel
08-30-2020, 07:03 PM | #7 | |
Re: 93 octane fuel
It doesn't have any more energy or higher performance. In a flathead it is a waste of money.
41 woodie https://41fordwoodie.weebly.com/ |
08-30-2020, 08:37 PM | #8 | |
Re: 93 octane fuel
09-02-2020, 08:01 AM | #9 |
Re: 93 octane fuel
I run non ethanol fuel which only comes in 93 octane in my area, no problems in my ‘41 or the snow blower, lawnmower.
09-02-2020, 09:00 AM | #10 |
Re: 93 octane fuel
09-04-2020, 03:03 PM | #11 |
Re: 93 octane fuel
My impression and my friends who have used higher octane gas in a variety of vintage vehicles is the car runs better -However its probably pyschological rather than scientific . The same pyschology that gets millions adding useless fuel additives to the gas tank.
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
09-04-2020, 04:00 PM | #12 |
Re: 93 octane fuel
I think he is referring to non-ethanol gas. I agree 100%. The ethanol gas causes havoc in small engines and motorcycles if left to sit for any extended period; even with Sta-bil, etc. in it.
09-04-2020, 11:01 PM | #13 |
Re: 93 octane fuel
When my dad was growing up in SE Massachusetts in the '30s, they lived behind his stepdad's gas station on rt 6. They sold something like 8 brands of gasoline. Flying A, Mobilgas etc and the loyal customers would swear by their particular favorite brand of gas... "ol Bessie won't even climb a hill on the cheapass stuff you're filling up on". Well, years later Dad told me they only had One underground tank and it was re-filled at night by a flat black painted fuel truck...
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
