07-31-2020, 12:16 PM | #1 |
Temperature Sender
My temp gauge reads about one increment high. When the water temp (measured by temp gun) is at 160 (should be the center mark) it reads 180 (the mark half way from center to the Hot mark).
The gauge seems okay. It buries on the hot side when open circuit, and buries to the cold side if the sender wire is briefly shorted to ground. The right side (single connection) sender is a reproduction. I can not find a NOS or used original unit. Is there a source for OEM senders? Is it worth $45 to try a new repro sender? If so, are they all the same, or is there a better quality supplier? |
07-31-2020, 12:59 PM | #2 |
Re: Temperature Sender
I would try Fred at Southside Obsolete (barnfind08 on here); he seems to have more NOS stuff than just about anyone. I have heard the repop senders aren't very accurate and are also short-lived. I might have a good used one in my stash if all else fails.
07-31-2020, 01:13 PM | #3 |
Go with what your temp gun reads and then recalibrate the gauge reading in your mind.
Over time the bimetallic heat strips inside the sender and the gauge may wear out just a little and not give perfectly accurate readings. Plus all temp sending units in the heads are not calibrated the same. So, a replacement may vary the readings. |
07-31-2020, 01:25 PM | #4 |
I don't know about the earlier gauges, but 48-on can be adjusted. Adjustments must be VERY small or the gauge will go crazy. One adjusts Zero, the other readings. According to the 48-51 Truck manual, you calibrate by connecting the gauge to a D-cell battery and adjust til it shows 50% of range.
'52 F-1, EAB flathead |
07-31-2020, 07:14 PM | #5 |
1980 ford gauges are near identical , more plastic but look the same . I remember osing the guts of a 80s ford something to repair a 46 or 48 ford gauge . Worked great . The 80 ford gauge cluster had a bi metal strip thing with the connections of 9 v transistor battery .
Ive got some already disassembled somewhere . |
07-31-2020, 07:19 PM | #6 |
I do the same with the temp gauge on my 54. Usual reading is about 3/4 towards cold. If it differs significantly from that I start checking things.
07-31-2020, 10:37 PM | #7 | |
For that reason, I want a fix. |
07-31-2020, 10:40 PM | #8 | |
07-31-2020, 11:42 PM | #9 |
gauges are notorious for being off so long as their consistent you can work with them some manufactures dont put numbers on them just zones [yellow green red etc ] so long as it stays around the same point its good what you look for is a sudden change
