10-21-2020, 06:02 PM | #1 |
Perch bolt ID
The perch bolts came out of a axle that was under a 1940 car but they look different from what i have seen in the past. ( just because it was in a 40 doesn't mean it started life there)
These are ford script with a bushing and grease fitting on top Question is, what were they originally for? |
10-21-2020, 06:18 PM | #2 | |
Re: Perch bolt ID
You will rarely see that design bar as they were well, not a good design. Most were replaced at the dealer when the (fairly) new car went in for other service. Most owners were never made aware of the swap.
10-21-2020, 07:39 PM | #3 |
Re: Perch bolt ID
Did they work with the swivle or was that changed also?
10-22-2020, 08:23 AM | #4 |
Re: Perch bolt ID
