09-22-2016, 08:17 PM | #1 |
1940 Ford Coupe Headliner Question
I am having trouble trying to figure out how to install the headliner in my 40 Coupe project. Does anybody know exactly what is required above the door openings on each side? Any pictures would really help. I bought a Labonny Barron interior kit. The instructions refer to a "grabber strip" on each side above the doors on the roof line. Is this a seperate piece that screws to the roofpanel? If so , I am missing these parts.
Is there a good reputable upholstery Trim Shop that I could hook up with to get some experienced answers to this question? Any contacts would really help us here. Thanks for any input or ideas. Steve p.s I already called BL and they no longer have technicians that have the experience to answer this . |
09-22-2016, 09:44 PM | #2 |
Re: 1940 Ford Coupe Headliner Question
The grabber strips fit over the door openings and slightly turn down the windshield post. They have teeth on them that holds the headliner when it's gets tucked behind them.
09-22-2016, 10:48 PM | #3 |
The grabber strips are not reproduced. You'll have to find them used. The strips from the front of a fordor sedan or from a tudor sedan will work. You'll have the shorten the ones from the tudor. You do need them to retain the headliner. Don't forget to replace the tack strips on the door posts for the windlace to attach securely. Trying to use the old tack strip material is a losing proposition.
09-23-2016, 10:05 AM | #4 |
The SEARCH box (Headliner installation) is your friend. 5th posting shows grabber strips.
http://www.fordbarn.com/forum/showth...r+installation Also, read this about headliner kits. http://www.fordbarn.com/forum/showth...r+installation This "wrinkle" post is also helpful. http://www.fordbarn.com/forum/showth...r+installation Last edited by 19Fordy; 09-23-2016 at 10:11 AM. |
09-23-2016, 10:48 AM | #5 |
these photos were posted previously on the barn.
10-08-2020, 12:13 PM | #6 | |
10-08-2020, 01:23 PM | #7 |
steve:
Take a look at this and watch the video. I bet you could use this flexible tack strip with some "creative thinking" and drilling mounting holes in it to mount to the car. The OEM strips do come up once in a while on Ebay. For the price it's worth a try. https://www.sailrite.com/Flexible-Me...CABEgIBHPD_BwE Last edited by 19Fordy; 10-08-2020 at 03:37 PM. |
10-08-2020, 04:39 PM | #8 |
See attached.
10-08-2020, 06:02 PM | #9 |
See if you can get a list of the former authorized LB installers in your area. They could probably help.
10-08-2020, 08:50 PM | #10 |
the grabber strips show occasionally, I just parted out 2 fourdor sdns and am using the strips. They do also rust out from condensation. Newc
10-09-2020, 05:50 AM | #11 |
FWIW, I believe the correct term for the "grabber strips" is Door Tins.
10-09-2020, 08:09 AM | #12 |
4dFord/SC: Thanks for that bit of info. I didn't know that.
10-09-2020, 08:21 AM | #13 |
I know I have one and maybe both, I also have the 2 pieces that get covered with headliner material along the edge of the windshield down to the dash. PM me if you need these.
10-09-2020, 10:29 AM | #14 |
contact Gary (40fords) he is in Delaware and has a lot of 40 ford stuff, he is on this website all the time
hope you find them geoford41 |
10-16-2020, 04:35 PM | #15 |
Save
